velocity 50 N2 Build Thread
  • #91
    Thank You !
    • #92
      Originally posted by praztek View Post
      I have a few questions / observations during my build. Thanks in advance.
      Exhaust line from fuel tank, routing through frame hole, thinking of putting something to prevent chafing
      i put a bit of heat shrink where it was touching the frame aslo i would sand it with a bit of wet and dry to get the sharp corners off
      Tbs discovery quad
      Align 700L Dominator
      Gaui x3
      mikado logo 480 Xxtreme
      • #93
        I have to say with the Fusion somehow in the vbar software it's the best Heli (value wise) I have ever set up. Even the tail the 2 figures are exactly the same and I never had that before and all the other figures appear bang in the middle. I was not looking forward to it originally cos of bell cranks etc but pleasantly surprised by it so I would imagine hitting the sweet spot in the beastx software should be as good??
        I do have a beastx here, if I get time before the maiden I can always plug my servos in and see how the set up goes?
        • #94
          Yeah, will def go back and sand that area, and possibly put some shoe goop around it , which should do the trick.
          • #95
            Praztek i had the same issue with the throttle link, i have got it as close as i could get it and will take it from there.
            Del
            Climb-Out
            3D Scotland
            Proud owner of 2 EGS
            • #96
              I'd just be interested to know if others are able to hit the 6 degree sweet spot with standard servo wheels but dont knock yourself out Ben, if its already set up on a V Bar its not worth interfering with it!
              Guy
              And an E.G.S!
              • #97
                I'll do it tomorrow night Guy happy to try it out
                • #98
                  Guy when i set mine up I will see if i can get it right, i'm not using the standard servo wheels though, i'm using Futaba ones designed specifically for outrage heli's
                  Del
                  Climb-Out
                  3D Scotland
                  • #99
                    Got a link?
                    Guy
                    And an E.G.S!
                    • Originally posted by Gate88 View Post
                      Got a link?
                      Hopefully Paul will have it mate, i got them off him
                      Del
                      Climb-Out
                      3D Scotland
                      • Guy it's these ones here that i have.
                        Outrage RC , LLC
                        Del
                        Climb-Out
                        3D Scotland
                        • I used four point Futaba star arms when I first set my beast x Up on the fusion guy & I had an altercation with the ground I then put on align plastic wheels & all is well
                          Martin
                          Aka RCSlopesurfer
                          • Originally posted by rcslopesurfer View Post
                            Yea sadly its the price of ann education!!!!
                            Guy
                            And an E.G.S!
                            • Sure is mate & ya won't catch me using em on flybarless again thats for sure.
                              Martin
                              Aka RCSlopesurfer
                              • nothing will beat a solid disc on fbl, i always use the mammoth huge futaba disc, the ones that hav a 19mm distance pre drilled, and i just drill my own holes, a disc is soooo much stronger than any horn purely coz its one piece, i cant flex or move at all
                                just my bit of advice
