velocity 50 N2 Build Thread
  • Originally posted by sacko View Post
    Definitely glue them in, they just fall out :S
    Zap Goo is what you need
    Where do you get this Zap Goo you speak off??
    • Skyline Models :: Tools & Accessories :: Glues / Lubricants :: PT12 - ZAP...
      This is the stuff.
      Servo plugs will not come out easily when hanging off them, but its comes off when you pick a bit off. It then pulls off in one hit, unlike hot glue.
      x 3
      • http://www.fast-lad.co.uk/store/zap-...2-p-11633.html
        That stuff there Ben, most model shops sell it
        Del
        Climb-Out
        3D Scotland
        Proud owner of 2 EGS
        • I love goop
          • al get some of that ordered instead then :P + i like how its nearly half price at skyline models compared to fl
            Tbs discovery quad
            Align 700L Dominator
            Gaui x3
            mikado logo 480 Xxtreme
            • I use this, it sticks like sh*t to a blanket put peels off easily when you want it to.
              PRO SEAL RTV Silicone Instant Gasket CLEAR 85g Hi-Temp | eBay
              Guy
              And an E.G.S!
              • Well thats it!
                I give up with the N2.
                I was soooo looking forward to this heli, it was supposed to be just like my V2 but better, sadly not, even my V2 stayed new for 4 minutes!
                Fridays maiden lasted 2 minutes and after 11 hours running round fetching parts, rebuilding, repairing, setting up, re checking set up, repairs, and everything else todays flight lasted less than 20 seconds. For some reason I had no control over the pitch once it'd spooled up, other than that I cant be arsed to investigate further & Im not prepared to spend any more time, money or effort on a heli that has only been available for 5 days and has already been in twice!
                One of my clubmates has it now and I'm going back to my Trex 600!
                I shall wipe it from my sig and my Avatar and never speak Velocity again!
                Guy
                And an E.G.S!
                • Gutting mate
                  You havent flipped the blade grips when rebuilding it? Had that happen at the field a couple of months ago, and he described the same thing.
                  x 3
                  • Del mate.... Did you get the BeastX set up?
                    If you can keep your head, when all others around are losing theirs - you have probably not understood the seriousness of the situation!!
                    • Yup as Sacko said, I'd put money on reversed blade grips after re-build. A mate did exactly that; You spool up, realise nothing is happening as you lift the collective stick, then slam it shut, only for the machine to jump in the air like a scalded cat, but then with the engine/motor now off, it sonn does a blade stop auto, resulting in a nasty landing
                      • Originally posted by Gate88 View Post
                        Well thats it!
                        [ATTACH=CONFIG]36146[/ATTACH]
                        Sorry to hear that mate. You havent had much luck.
                          Gutting mate
                          Yea you might be right mate, but I didnt bother looking over it much afterwards, as it hit the ground and bits flew off it I just thought "Life's too short!"
                          I could see that all the links have broken off the head again but there's no way of telling what was cause or symptom!
                          Guy
                          And an E.G.S!
                          • Looking at your picture, it looks like its setup as trailing edge control on the blade grips, but looking at the manual here: https://outragerc.com/manual/Velocit...06-01-12_5.pdf it shows that it should be leading edge
                              Gutting mate
                              Yes a quick phone call to my mate who has it now does indeed confirm that the grips are reversed. I guess thats what spending too long on a model does to you, it gets to the stage where you cant see the wood for the trees!
                              Guy
                              And an E.G.S!
                              • The one and only original...
                                http://www.amazon.co.uk/dp/B0010YTLU...U&linkCode=asn
                                Member of Mk Heli Club
