You would be better running those two servo cables on top of block and secure around necked portion of block. The way you have it now you risk fretting cable to block edge and possible fretting from servo horns.
. I have now moved the aileron and pitch servo wires so they go under the servos then above the motor mounting plate and across to the right (from the back) then under the gyro/anti rotation bracket to the 3GX. I have kept the rudder and ESC cables the same to avoid contact with gears/servo's.
x 3
