Align T-rex 450 Pro 3GX build
  • It may not have been you as if it was over tightened at the factory the bearing may have already been damaged. When you get new bearings in let the thread lock do it's magic
    Again good save!! I would definitely be carrying a bag of bits (like my mcpx today)
    Gaui R5 + 14S + Tribunus 200 + Scorpion 4530/540 + Bavarian Demon Axon
    Gaui X3L + Bavarian Demon 3SX
    Jeti DS-16, Citizen 625
    iMac + AccuRC =
    Member of East Fortune Aeromodellers
    Jeti Sensors and Apps: https://github.com/AlCormack
    • That's exactly what happened to a bearing in my tail grip too, locked the tail blades and the servo couldn't move them at all. With the same outcome too, except I stripped the umbrella gear. cheapo bearings it would appear.
      Sent using pigeons.
      Synergy N5 -BeastX
      450 Pro -BeastX
      Black Horse Sukhoi 31
      DSX9
      Eagle RC Heli Club
      • Hey
        Thanks for the help guys. I checked the other bearing and found nothing wrong. But have stripped and cleaned and re applied thread lock just to make sure. Just waiting for the bearings to turn up now then will be back in the air.
        Rich
        SAB Goblin 700C - Black Nitro
        Flight Log
        THE MEDWAY MASSIVE
        WEBSITE FACEBOOK
        • just watched the video - well done mate!!!
          hopefully i will be with you this weekend :-\
          • Had a maiden yesterday. Not good tail bearing on mine are good but the tail shaft is not manufacturer correct there is play on the shaft after umbrella before it goes in bearing. On take off starting to spin so landed on some twigs and striped forward torque tube gears. Twigs what crap are these things made of. Also having troubles fitting canopy anyone else?
            Raptor 50 v2, trex 600n fbl, trex 550 v2 3gx, trex 450 3gx v2, mini-titan v1, mcpx v1, WoT4 foamE, Gootch 450, mcpx bl.
            • hi rich you get my pm
              • Check out the pictures of my canopy earlier in the thread. Im almost there straightening it out but its stressful work lol.
                My shiny new tail bearings turned up today so will be fitting them tomorrow or friday then back out for testing Friday afternoon!
                Flight Log
                THE MEDWAY MASSIVE
                WEBSITE FACEBOOK
                • Hey
                  The pro is all fixed and awaiting a test flight in the sunshine/cloud. I have turned the roll rates down to 30 on the 3gx so I will let you know how this goes, hopefully with a video, tomorrow
                  Rich
                  Flight Log
                  THE MEDWAY MASSIVE
                  WEBSITE FACEBOOK
                  • Originally posted by Rich23 View Post
                    Hey
                    Rich
                    Turning roll rates down to 30% I'd suggest turning gain pots up to between 2 to 3 0'clock maybe more to give swash faster stabilisation
                    • Flickr Through My Pictures.
                    • Hi Jim
                      What will this do exactly? Just affect the swash speed?
                      What I'm trying to do is slow it down a bit when going forward, back and left right as I find it a bit to twitchy at the moment.
                      Rich
                      Flight Log
                      THE MEDWAY MASSIVE
                      WEBSITE FACEBOOK
                      • +1 on what jim says (I turned mine just past 1 o'clock). I found it "locked" the heli in much more. e.g. when hovering or doing a piro it stayed in one place.
                        All the best with the next flight. Will hopefully fly mine at the weekend with the new esc
                        iMac + AccuRC =
                        • hey
                          I will give that a go too.
                          Rich
                          Flight Log
                          THE MEDWAY MASSIVE
                          WEBSITE FACEBOOK
                            Hi Jim
                            Rich
                            With the 3gx if you lower the parameters you then need raise the gain pots this then will level the heli much quicker & give heli a very stable heli, as you progress you'll find you will need to up parameters & drop the gains, a 3D pilot would have there gain about 11ish & parameters to default settings or above so everything is set around the swash behavior, if you connect heli to the pc & move the parameter scale from say 0% to 100% you will soon learn how the swash behaves same as the gain just turn pots to zero & tilt heli the turn the full clockwise & tilt heli you will see which way the swash levels out the fastest so if you in the hover learning stages & small maneouvers you need to be on the high side of the gain & lower side of paramerter default setting.
                            Sample"
                            Roll rate 30
                            Swash tilt 40
                            Cyclic damping from zero to 50%
                            • Thank you Jim I understand now. I will adjust the pots to 2 o'clock ish with 30 roll rates.
                              Thanks again
                              Rich
                              Flight Log
                              THE MEDWAY MASSIVE
                              WEBSITE FACEBOOK
                              • Hey
                                A quick update. I just adjusted the pots and had a quick flight and wow the hold is better and it seems more stable in the hover. But landed it and caught the stick which tipped it over just enough to catch the blades!
                                Looks like I got away lightly with just 2 bent pitch rods.
                                Will check the feathering shaft later just to be on the safe side. Ordered the titanium turnbuckles with 1 normal thread and 1 reverse thread to replace the bent ones. Any one used these before?
                                Rich
                                Flight Log
                                THE MEDWAY MASSIVE
                                WEBSITE FACEBOOK
