Tarot ZYX flybarless
  • #31
    Originally posted by choppertastic View Post
    Do you have a link to the site you got it from. Am interested in one myself.
    James
    Think it was here :
    http://www.oomodel.com/tarot-450-pro...3-p-62438.html
    or
    http://www.moonhobby.com/tarot-450-p...o-p-61832.html
    Dan
    Goblin 500
    | Blade 130x | Blade 180cfx
    Spektrum DX8
    GWR Pilot 2011 & 2012
    • #32
      Tarot Helicopter : OOmodel.com
      Hope its ok to post this here, if not apologies and just remove it.
      • #33
        Just a heads up, always intended to tell it how it is, and on starting the build have found the tail slider binding (will replace with Align, as i doubt there will be any after sales from China) and 1x henge cyclic servo MD933 is faulty , and not centering correctly.
        • #34
          This is the thing with clones. I found dodgy tails on all of mine and have replaced with an Align tail unit, so factor in this cost of about £40 for a new tail tail box plus tail grips and rotor shaft).
          RCHA Member
          LFXproductions.co.uk
          • #35
            True, I guess you live and learn...
            • #36
              tails seem to be a problem with the clones ive got a few clones (copterx and hk450 ) and its always the bloody tails i seem to have problems with but out of them 2 i prefer the copterx but same as everything you get what you payfor and always check everything this is a second hobby for me so i dont want to spank a lot of money ( but its slowly takeing over ) ive got the copterx flybarless unit but due to a servo going bang on me im useing it as a tail gyro at the moment till i repace the links in the fbl head but im using the hacked software to program it on pc but they have released the pc software now so i think ill have to get the links and give it another try but as a tail gyro its not bad lol
              JAY
              owner and driver of the fastest astra mk2 in the uk
              now learning to fly a heli and doing it bad
              • #37
                Is that the plastic arm ? Tarot also do a metal arm that is very nice
                • #38
                  I take it your meaning on the tail slider Mike? if so, yes. But i think it may be the actual shaft thats causing the issue. Decided to change the tail for Align, and i am going to swap out the remaining Henge servo's as i dont have any confidence in them now, So i think i'll go for HS65mg's on the cyclic, and Ds520 on the tail, unless anyone can give other reliable servo's that would be suitable.
                  • #39
                    I have built both the sport and the pro tarots and both kits had sticky tail sliders. I rolled some wet and dry into a cone and reamed both ends of the slider bushing as it was poorly machined. Tail was nice and free once done. ;-)
                    • #40
                      Im looking to try this unit on my beam in the not too distant future, got to be worth a punt considering the price
                      cheers Lee
                      • #41
                        Hopefully youll be plesantly surprised
                        Lee
                        www.raptoruas.co.uk
                        www.lee.rcha-uk.com
                        www.gensace.de
                        • #42
                          Well what's it like any good.
                          Raptor 30v2
                          Skya 500 x 2 one to be Scale Bo 105
                          Copter X450 x 2
                          Trex 250 x 2
                          Mcpx
                          Raven wing.
                          Suhkoi
                          Anx Floater
                          Radjet 800
                          DX7
                          Phoenix v4
                          Proud to be member of SCHA
                          Log Cabin for Hire in Snowdon.
                          http://www.youtube.com/user/streetlu...s?feature=mhee
                          • #43
                            any more people with the ZYX? i'm just about to rip mine open (the box) and have a fiddle with it.
                            any good links to a set up?
                            do i need to rip all my present servos to test with this thing?
                            • #44
                              Like any FBL, just make sure the servo settings (frequency etc) are all set right before connecting the servos.
                              Harry
                              Powered by Futaba 18SZ
                              • #45
                                thanks - i'm just familiarizing myself with the software.
                                I brought the gyro with me and the USB to play at work but guess what - the gyro needs a power supply to power up (I thought the USB alone would power it - oh well)
