Originally posted by raptorheli2
View Post
Align servo's.. Trusted ?
This topic is closed.
I've just fitted three 610 servos on the Outrage 550 having replaced all three servo case tops just prior to fitting - so I'll keep an eye on them and report back if they fail again...
RobTeam Align, Midland Helicopters, Optifuel, Cyclone Blades, Scorpion Motors, Thunder Power, Savox Servos, JR Propo
| 3D Championship
i'll buy them £5 each ?Originally posted by raptorheli2 View Posti was under the impression this was fixed a long time back. perhaps that info was wrong or is that an older servo?
i have 3 spank new 620's in box for my velocity so wondering should i sell em now or use em.
cheersMike
www.RC-Scotland.com
TZ Frenzy .53 Red Line
T-Rex 600 .52 ASP
T-Rex 600 .80 ASP 4ST
I like the align servos in both my aurora and 600NSP and think for the money they can't be beaten. got some hitec hs 6965's linned up for my velocity but might put some 610's in instead if i have the avaliable fundsJames
Sponsored by
Align-Trex.co.uk
Optifuel/optipower
MKS servotech
arn't the align servos made buy hitec?Originally posted by moonmanflyer View PostI like the align servos in both my aurora and 600NSP and think for the money they can't be beaten. got some hitec hs 6965's linned up for my velocity but might put some 610's in instead if i have the avaliable fundsHirobo Turbulence D3
1/4 scale Vario Bell 47 G3
1/3 scale Vario R22
2012 LHC Scale Cup Judge
If you haven't bought them already, I would go straight for the Align servos instead - they centre better than the Hitec's. You want a servo that centres well on CCPM setups.got some hitec hs 6965's linned up for my velocity
No, they're made by Savox.arn't the align servos made buy hitec?
| 3D Championship
Already have them rob, on my lads pro so was going to just use them for now but might get the 610's anyway and keep the 6965's for something else, i.e. when my lad harry wants something biggerOriginally posted by robgt View PostIf you haven't bought them already, I would go straight for the Align servos instead - they centre better than the Hitec's. You want a servo that centres well on CCPM setups.James
Sponsored by
Align-Trex.co.uk
Optifuel/optipower
MKS servotech
i didnt know they were made by savox
thanks guysHirobo Turbulence D3
1/3 scale Vario R22
Unexpected failures like that are a sure sign of high frequency vibration, the kind you often can't see, but can sometimes (but not always) hear. Is this the Vibe you've got the Redline 53 in? These engines have loads of grunt but are certainly not as smooth as their OS and YS rivals.JR Vibe Fifty fb (YS56)
Guy's,
Thank you for the reply's
Intresting to see that most people have no issues and means I'll stick with them for now and just an eye on them
The reason for more than one vote was simple you may have found the servo was bad for you and then changed to something else
Sometimes there is more than one answer basically
So thank you for the reply's and posts
I have not used any align servos as yet but considering there does seem to be an issue with the cases I tend to think;
1. Perhaps they are more vulnerable when mounted directly to the swash on a CCPM setup vs a push-pull linkage arrangement.
2. They might benefit from a brace like the Blitz Avro uses.
3. They might need extra care to make sure the pressure on all four mounts is as close to equal as possible so there's very little stress on the case to begin with.Kasama, Minicopter, Henseleit, JR, Shape, Beam
Proud recipient of 7 EGS!
and a platinum star
