Re shrink wrapping lipos
  • Re shrink wrapping lipos
    I know this can be done but can anyone advise on which size shrink I would need for a 6s5000 lipo?
    Any pointers on decent supply would be appreciated too....cheers!
    This any good : Heat Shrink 1M Strip Clear 90mm O-LG-HS90
    Actually that might be too small for a 6S, what are the dimensions of the battery?
    Could need something like this :
    100mm X 1.2m Adhesive Heat Shrink Sleeving 3:1
    Goblin 500
    | Blade 130x | Blade 180cfx
    Spektrum DX8
    GWR Pilot 2011 & 2012
      Yeah, saw that but wasn't sure of the size required. Didn't know if 3quid a metre was the going rate too
        Also here : items in Mister Shrink store on eBay!
        If your pack was 40 x 50 then the 100mm will do
        Add the size of the 2 sides together to get the minimum size shrink tube you need
        Goblin 500
        Spektrum DX8
          They are these. HobbyKing R/C Hobby Store : Turnigy 5000mAh 6S 25C Lipo Pack
          They are 150x50x52 I just can't work out if the measurement of the shrink is diameter when open or flat.
            It's the diameter when open, actual size when flat is 158mm
            So your battery would is 204mm total measurement & shrink wrap is 316mm total
            So that size should do you fine as it shrinks to a maximum half size.
            Dan
            Goblin 500
            Spektrum DX8
              Or you could get this Turnigy branded to match the batteries
              http://www.hobbyking.com/hobbyking/s...dProduct=11412
              Goblin 500
              Spektrum DX8
                Try this in the UK good service. from memory its 105mm
                Battery Shrink Sleeving (Matrix) - Cell Pack Solutions
                Trex700E sold
                Dragons450 gy401 s9257
                Mcpx
                JRDSX9MK2
                coolice Power Supply
                  Perfect timing for this post. Need to re-wrap a 6s 5000 and just went to Cell Pack Solutions as recommended by Red3. Very easy to order and PayPal is available for payment if you don't like using card online.
                  Nick
                  Rave Ballistic FSO Black - Fusion 50 - Goblin 500 - Synergy N5
                  Skookum SK540 - VBar - 12FG - Pheonix
                  Planks: Elf, Blaster 3, Orion DLG's - CTH & Raven Flying wings
                  Heli History: MCX - MSR - Walkera V200D02 - Gaui 550 - Trex 450 Pro - MSH Protos - Gaui 200 - Logo 400SE - Goblin 630
                    Just for clarification. The diameter shown on Cell Pack website is flat so if it shows 105 then that will go round a pack that measures 210.
                    You need to find the size closest to what you need so that it shrinks the least amount. I know it will shrink to half its size but it will look crap.
                    Member of Mk Heli Club
                      Which size did you go for?
                        Optipower sells it. Allthough out of stock, FL sell it, and i'm sure Midlands will have it as well.
                        This is what I used, but it is tight getting the cells in as well as a 2mm carbon back bone to make up my 12s sticks.
                        Opti Power Stick Conversion Kit For 5000Mah 6S Batteries
                        Henseleit TDR V-Bar x2
                        SAB Goblin 700 V-Bar
                        T-Rex 700e DFC V-Bar
                        Synergy N7 V-Bar OS105 HZ-R
                        Synergy E7se V-Bar
                        Synergy N5c FBL V-Bar
                        Gaui NX7 V-Bar YS91 Tareq SRX
                        T-Rex 550 E FBL V-Bar
                        Gaui NX4 V-Bar
                          I've just measured my spare ones, and they are 92mm wide. This will NOT be big enough for Turnigy packs. The Opti packs are smaller.
                          Synergy E7se V-Bar
                          Gaui NX4 V-Bar
                            So the 128mm strips from Cellpack should do the job?
                              Cell Pack Solutions sell in metre lengths large enough to go round a battery measuring 338mm for £1.80.
                              I will leave it to you as to whether you think this is better value or not.
