Originally posted by Reality Bites
View Post
Re shrink wrapping lipos
the 6S 5000mah Turnigy's are 20.5cm or 205mm - 105 should do the trick then ... probably a bit larger than 105mm ...Sev
Thunder Tiger E700 BD3SX
Trex 450L DFC BD3SX
Trex 150 PRO DFC
Blade Nano CP X
Blade mCP X v2
Blade 130X
DJI Inspire 1
DJI Phantom 2 iOSDmini
EMAX 250 Pro V2 FPV Racer
Futaba 18MZ
MK Heli Club MKMAA
Proud Owner of:
Originally posted by Reality Bites View PostWhich size did you go for?Exactly what I did, 2mtr of 105mm and 2mtr of 128mm.Originally posted by Andy from Sandy View Post210mm is perfect. It only has to shrink a tiny amount and so will stay thin. As heatshrink shrinks it gets thicker. As the stuff is so cheap get the 105 and the next size up just in case.
I can pop round with it when it arrives and you can see which suit best?
Nick
Rave Ballistic FSO Black - Fusion 50 - Goblin 500 - Synergy N5
Skookum SK540 - VBar - 12FG - Pheonix
Planks: Elf, Blaster 3, Orion DLG's - CTH & Raven Flying wings
Heli History: MCX - MSR - Walkera V200D02 - Gaui 550 - Trex 450 Pro - MSH Protos - Gaui 200 - Logo 400SE - Goblin 630
Just thought I'd feedback on Cell Pack Solutions. My wrap arrived yesterday and it looks good. Nice and thin so shouldn't add much to the overall size of the lipo.
Nick
I had a couple of orders with them and spot on service.Trex700E
sold
Dragons450 gy401 s9257
Mcpx
JRDSX9MK2
coolice Power Supply
Thought I'd share some pics of the re-wrap. I've re-wrapped some Turnigy 6s 5000mAh 40-50C using the 105mm sleeve from Cell Pack. It's a snug fit to start but easily done and the shrink rate was good with a low set heat gun. Final finish is very good and as good as the warp you'd find on the originals.
Nick
I had to open up a pack to re solder the balance lead back on I didn't want to bin a pack just for a wire coming of.Trex700E
sold
Mcpx
JRDSX9MK2
I bought some packs 2nd hand and they where wrapped in black tape and a thick shrink sleeve. Because of this they wouldn't fit between the frames on my Rave. So I stripped them back to the cells and put the new wrap on. No they fit snuggly.Originally posted by muscleflex View Postwhy are you guys re-wrapping your cells?
Nick
as far as i know cellpack only do black.Trex700E
sold
Mcpx
JRDSX9MK2
