The magic smoke!
  • #61
    lol, heat it up in the oven...it was the grill.
    Goblin 500 SK540 jive 100lv
    HD 500 SK540 jive 80 lv
    Oxy 3 SK540 minijazz20
    • #62
      Oops, meant the circlip was at the non-rotating end. But now it's been mentioned, maybe not all motors have them. I'll check later scorpion.jpg
      • #63
        Using the ones in the kit,they don't look to long tbh.
        I couldn't look in the motor as I couldn't see how it comes apart,no grub screws to be seen anywhere.
        If the esc produced smoke you would be able to smell it yeah?
        Had esc off last night and it smelt fine.
        Align motors are different from the scorp motors which are easy. Some have a grub screw or two at the opposite end from the pinion which are visible in the air vents to unscrew. You then need to push the shaft out from the bottom of the can with a press or vice. There is no easy way to get to the stator and magnets I'm afraid.
        • #64
          No circlip,no grub...align dont sell the shafts either!
          Fitted a 450mx in over at Quick Uk and spooled up to flat out,no smoke,no smells and motor never even got warm....the only downside is i never just bought the 450mx....well,you know what its like in these places haha
          And no Heathy,i never came out with a 800dfcor a DFC shirt! LOL
          • #65
            Well? Bring it tomorrow then.
            • #66
              So you came out with something else tucked under your arm. I know that feeling.
              • #67
                Yes but in a bag lol...another dsmx sat,450 swash leveler,some velcro,small servo ext lead and a 6" sat lead
                • #68
                  Damn right!!!
                  • #69
                    The shafts are reusable. It's just a press fit into the can with the bearings in either end of the stator. Have you returned the motor?? What's the kv difference between the 450l motor and the older 450mx 6s motor?
                    • #70
                      450 MX = 1700Kv
                      450 Dominator = 1800Kv
                      Collector of SAB Goblins
