What you sayin punk?
The magic smoke!
Originally posted by cjcj1949 View PostIt did work for a bit on spoolup. Something must have happened. Could this be the well known screw problem. The mounting screw length and the width of the mounting plate have to be just right. Too much screwing often cuts into the wire going to the motor and connects it to the screw. So motor gets screwed and then esc gets screwed which then screws the motor a bit more. It could be a simple mechanical design problem, not electronic at all. What Steve and Vikki said sounds good. Learning how to check things with a cheap meter saves a lot of money in the end.T- rex 600n V-bar
Originally posted by heathy View PostWhat you sayin punk?T- rex 600n V-bar
And why's that? Nothing to do with the crash you forced me into?? Nothing to do with combo deal electrics hey, I'd never buy anything where I'm forced into cheap inferior electrics. These align Helis must be something hey, people defend them till the bitter end. Lol.sigpic
Goblin 500 SK540 jive 100lv
HD 500 SK540 jive 80 lv
Oxy 3 SK540 minijazz20
Originally posted by heathy View PostAnd why's that? Nothing to do with the crash you forced me into?? Nothing to do with combo deal electrics hey, I'd never buy anything where I'm forced into cheap inferior electrics. These align Helis must be something hey, people defend them till the bitter end. Lol.T- rex 600n V-bar
Different ball game, besides there all piles of poo too. Take a look at the hard facts here, you purchased a new align Heli combo, and before your airborne it's failed. Take the electrics out, replace and fly.sigpic
Originally posted by Nick B View PostOh,im not defending align heli's,they are still shit lolsigpic
The best answer, you were weak and your therapy starts on Saturday.sigpic
Originally posted by Nick B View PostDid spool up last night with no pinion a few times and it was fine,i have reprogrammed the esc and put it all back together,all seems to be working again now
Do check that the motor mounting screw isn't nearly touching a wire. There is something very wrong with what you have at the moment. It might go again with extra mechanical load or vibration. These things can be checked without destroying other bits. Lipos and escs destroy themselves very easily.
If you have a linear BEC it will fail with your setup as soon as start to load the servos by pulling collective.Flasher 450 Sport. Assan GA250 with 520 tail servo, MKS DS450 cyclic.
Blade 130-X, MSR, MSRX
Phoenix Sim
Originally posted by heathy View PostWhat you sayin punk?Tom
Motor worked actually. It was a damaged heli jive from the crash causing the initial problems! As for the servos, again they worked only not powerful enough, no danger of catching fire, letting out magic smoke like in this case. Again, testament to buying quality gear. Had that been a cc or align esc then I'm 100% sure I'd be into a lot of pain right now. You boys can try as hard as you like to justify it, you just can't deny the simple equation
Buy cheap = buy twice!sigpic
What shall I do,it all works again so what do I say to the shop?
Blades off and spool up in garden?T- rex 600n V-bar
