The magic smoke!
    Now im confused)not hard lol)
    I just tried the cyclics and the work now,so i spooled up motor and its not right,it stutters and smell funny lol.
    why are your sats flashing??
    Sev
    Thunder Tiger E700 BD3SX
    Trex 450L DFC BD3SX
    Trex 150 PRO DFC
    Blade Nano CP X
    Blade mCP X v2
    Blade 130X
    DJI Inspire 1
    DJI Phantom 2 iOSDmini
    EMAX 250 Pro V2 FPV Racer
    Futaba 18MZ
    MK Heli Club MKMAA
    Proud Owner of:
      What happens if you unplug the motor? Does the 3GX and all cyclics respond correctly? If so, that surely rules out the 3GX and points you towards the ESC or motor ... ?
        Because i unplugged heli a few times.
        I just plugged everything in,all works correctly except the motor,it did work fine once just now but stuttered again next try and smells,its a funny smell,not your normal motor smell!
        Jim has had the same thing happen by the looks of things.
        Gonna take a look in the motor.
          Vikki... no chance nick don't know how to change a fuse he will never find the Ohms range on a meter... looks like a job for me at weekend...Steve
          Steve...
          Outrage RC Field Rep
            be in the bin by weekend lol
              I know how to change a fuse. I go into the shop and say "I wanted a 2A fuse and you sold me a 3A, would you change it please".
                give it me I have a spare helijive and vortex here I can make it fly...
                Steve...
                  Haha...will need more room to mount it all!
                    Told you. Kontronik koby 55lv. Scorpion motor and a decent gyro. Problem solved. Now the combo deal doesn't look so appealing does it??
                    Goblin 500 SK540 jive 100lv
                    HD 500 SK540 jive 80 lv
                    Oxy 3 SK540 minijazz20
                    • #25
                      Nothing wrong with the combo deal....how much did the warp cost you mate?
                      • #26
                        You can't measure quality with money mate, tell me why your running jives on all your Helis.?
                        I spent on the warp as I didn't want issues like this, simple. Anyhow, my grill doesn't work.
                        • #27
                          Lol, read that back to yourself as you sit there with a buggered brand new Heli.
                          • #28
                            It's strange, align esc's altough not the greatest thing on the market are pretty reliable. Align also know how to make a damn good motor, they make loads of motors for other stuff to.
                            It just seems like a duff esc/motor, I've had plenty of duff radio gear and never had an issue getting it replaced. It just an issue as most shops probably don't have replacements at the mo.
                            Invertix 400
                            Vortex 285
                            TBS Discovery Endurance
                            X4 II
                            Schluter Champion Longranger
                            G4 E720
                            G4 E720 Big AIR edition
                            Goblin Urukay super slow
                            Goblin 700 KSE Slow
                            Goblin 700 KSE Fast
                            Srimok Faifa
                            Spectra G
                            Synergy 766
                            http://mangled-rc.com/
                            • #29
                              It did work for a bit on spoolup. Something must have happened. Could this be the well known screw problem. The mounting screw length and the width of the mounting plate have to be just right. Too much screwing often cuts into the wire going to the motor and connects it to the screw. So motor gets screwed and then esc gets screwed which then screws the motor a bit more. It could be a simple mechanical design problem, not electronic at all. What Steve and Vikki said sounds good. Learning how to check things with a cheap meter saves a lot of money in the end.
                              Blade 130-X, MSR, MSRX
                              Phoenix Sim
                              • #30
                                Um...X7??????????????????????????????????????????? ???????????
                                haha
