700LE Build Commences
  • Thanks for your kind words. I've use the plastic "braid" on all of my builds and, thus far, it's served me well.
    I did try the braided sheathing stuff, but made a pigs ear of it and gave up.
    Martin
    • I pondered for ages on where to get cable sleeves from and then I had a eureka moment I remembered I had some cable tidy from a old pc power supply, removed the old heat shrink from it and its perfect.
      • Nice Clean wiring
        Might want to put a bead of Hot glue along the plugs to stop the pulgs from vibrating out in flight
        I left the hobby 3 years ago and discovered Women.
        I wish I never left.
        • Originally posted by Satch View Post
          What are the two bits of fuel tubing on the battery mount for Satch?
          Avant mostro 700E
          Avant mostro 700 Nitro
          member of :
          South cheshire heliaddicts
          • Originally posted by Dannyyy View Post
            Nice Clean wiring
            Its difficult to see but ive wrapped aload of electrical take around 'em for that reason, I was pretty worried about it myself hopefully itl hold .
            If that post was for me mate
            It was there when I got the heli, I assume its to stop the canopy from hitting the vitals like the battery etc, I assume though lol.
            • Thanks Satch. I bought the stuff I used from Maplins. I just couldn't get on with it.
              If I could find some fabric-based sleeving I might try that tho one day.
              p.s. looks like Stuart has turned on the image resizer system - thanks Stuart.
              Martin
              • p.s. looks like Stuart has turned on the image resizer system - thanks Stuart.
                I think its the way ive posted the images :/, they arnt the original full blown ones but a resized scale version that I found I could use.
                Its annoying when you have a 1024px image in the forum so the resizer was good at dealing with them.
                • Loom tape is what ill be using from now on
                  Used braid before and after a while it just looks a mess, also the heat shrink at the end of the braid rubs on the cable.
                  x 3
                  • Just about ready to fly. Only thing to do now is adjust the gyro gain.
                    I've set the heli up to achieve -12, 0, +12 in linear settings and I've tamed it down via pitch curves to achieve -2, 0, +10.
                    I'm absolutely gob smacked that the pitches on the linear setting were spot on on both sides. Not one fraction of a turn required on the links to get the blades equal!!
                    Martin
                    • go on marty boy!!!!!
                      • -2? Crank it up man!!
                        • I think u might want more than-2 in the negative mart, imo, it's up to u though
                          Chris 'CHUNK' Newby
                          ALIGN-TREX.CO.UK team pilot
                          LYNX team pilot
                          SPARTAN team pilot
                          Dx18
                          • Why would you need more than -2? (Mart's im normal mode im presuming)
                            x 3
                            • All of my other machines are set up this way. Is there a reason why I need more than -2 on the 700? Do the larger blades develop that much more lift that I'll need more to keep it on the ground?
                              In spite of my fleet, I'm still very much a learner flier.
                              Martin
                              • I have -2 just to prevent hard landings, though now I just mini auto them all down.
