Did YOU fly today??
  • Did I fly today? Couple of flights early evening before dumb thumbs took the Esky Sport over the hedge. A burst of juice and back up it came, but then the wind got it and I fought to get it down but it kept travelling upwards and further away. Finally I just killed the power and gave up trying to save it. Last seen about 200 yds south plummeting into someone's garden.
    That's me and FP done - I'll keep the unused one as a shelfie while I look for something else.
    • Maidened the cheap and cheerful 500 and trying Radix 690 V2s on the Faifa. The Faifa is great (and sharing packs with the 500! ) The Trex tail is a bit wonky, I fiddled with the gain but I think it's prob too much mechanical slop so I'll have to see what I can do with it before I take it out again, otherwise it's all working as far as I can tell
      • the R22 and the Bell 47 were both out this weekend
        the Bell 47 after its 2 year lay off has had a few fueling issues and although flying very well it needs it fuel tank looking at again
        as it not delivering the full tank of fuel
        an auto Saturday after the clunk line came off
        and today running out of fuel after 11 minuites of running (it should still have over 1/2 a tank left)
        both will be flying at the Cambridge Scale Fun Fly next week end
        Hirobo Turbulence D3
        1/4 scale Vario Bell 47 G3
        1/3 scale Vario R22
        2012 LHC Scale Cup Judge
        • Just returned from our field with a broken Trex 250. Poor thing went mad and started doing very advanced 3D moves before i flicked the throttle cut switch about 10 feet up. She came down on her side and little damage apart from another stress crack in the canopy,one bent skid and a broken plastic DFC link - all caused by the V BAR coming loose because the glue on the gyro pad had given up in the heat. In fairness she had been on the bench in full sun for at least an hour before being flown but on the way home from the field the rear view mirror fell off in the motorhome because the double-sided pad holding it to the windscreen had the same problem. Must check all the other gyro pads as they say things happen in three's.!!
          Have fun and stay safe.
          Barry
          Barry
          Sutton Coldfield Radio Controlled Aero Club (SCRCAC for short!) Citizen 00182
          Two Blade MCP-x
          Two Blade 130x
          Red Bull 130x
          Gaui 200 V2 FBL with mini V Bar
          Trex 250SE FBL with mini V Bar and DFC head
          2 x Honeybee King 2's (now retired)
          Mini Titan E325 with Tarot DFC head and mini V Bar
          Gaui 550 CF Hurricane FBL with mini V Bar
          HK Cessna 182 Deluxe, Silver Lady and Graupner GF-15 EDF (just for relaxation)
          And a tolerant wife, what more could any man ask for?
          • Pretty much got the tail sorted on the 500 now. Earlier in the week I tried moving the link on the servo wheel and a different hub and grips and it was just not working with the DS525 servo. Now I have a 9257 and it's working pretty OK, not perfect but I can live with it. The Beam 450SE is great for something so small, and today they are twins with matching canopies.
            • Originally posted by trillian View Post
              Is that a firing range in the back ground?
              Oxy 2 - Spartan VX1n
              Trex 700XN - Spartan VX1n
              Trex 700N DTS - Spartan VX1n
              Logo 690SX - Spartan VX1e
              780L Top - VBar Neo
              2 x 700L Top - Spartan VX1n
              Logo 550SX - Spartan VX1n
              Jeti DS14 BK edition
              DX9
              Pheonix R/C
              AccuRC
              neXt
              • Originally posted by chrisleematt21 View Post
                Directly in the background is an old WW2 era building that was part of the Chain Home radar network at RAF Swingate. It has one floor above ground and then stuff underground.
                • Had a good day at Sunny (as usual) MK.
                  I tried some different blades on my 600 but couldn't detect any difference between them.
                  There wasn't much wind so I had a dozen flights with the foamy; superb fun.
                  • I pottered about the sky with my benzin trainer
                    and gave the 600nitro a good thrashing
                    I also carried out a multi rotor A test for a fellow club member
                    I don't know what he was worrrying about, the flight was perfect
                    1/3 scale Vario R22
                    • Maidened the Shape S8. It was perfect right from the start, no FBL changes needed, not even tail gain! Couldn't ask for a better maiden. I suppose the only thing that surprised me was that despite it's size it wasn't really very different from my light 700s in terms of the way it looks and flies. The sound is great though, very quiet drivetrain and those big blades.
                      • Looks awesome. That's a heli with a whole bunch of physical presence. I bet it makes most 700s look like a 450.
                        • Originally posted by Grumpy View Post
                          Yeah it's certainly very large on the ground and when transporting it. It took me a while to find a suitable bag to carry it and I improvised a canopy cover out of a motorcycle helmet bag. But my impression is that once it's in the air the subjective look and feel is very similar to the lighter 700s. Visibility is very good as you would expect. The drivetrain is smooth. I periodically checked the crown gear as I had heard about someone melting theirs from an overly tight mesh but the gear was always cool. It was pretty warm here yesterday and everything ran really cool. The motor was only just warm after a 6 minute flight.
                          It's fun to fly, super stable as you'd expect and would be great for F3C hovering. The battery layout is very flexible for different size, shape and weight packs. At some point I'll check the logs to see what the average and peak amps look like, I know there's an energy price to be paid for all that mass but I'm sure it's less than what some guys pull flying smaller helis really aggressively.
                          Here's my 6ft surfboard bag, works great so far but it's massive!
                            Is that a 250 next to it
                            Looks like a really nice heli, I'm surprised it flies like a light 700. Did you get it from freakware?
                            780L Top - VBar Neo
                            DX9
                            Pheonix R/C
                            AccuRC
                            neXt
                            • That is a Beam E4 SE (450) which is the smallest heli I have. I got the Shape from a guy that bought it as a combo from Freakware and he flew it only a few times and then decided to sell it. I rebuilt about half of it (well most actually, all the moving parts) and put in my own motor and ESC and FBL (Spartan VX1). I did buy another canopy in yellow from Freakware and I also had to get the correct RH side bellcrank as the kit had been supplied with two left bellcranks and this was not noticed by the original owner. Freakware gave me the bellcrank, which was cool of them.
                              Yeah, because I am running my 700s at low headspeeds, the apparent feel is very similar. So the Shape is a lot heavier but is compensated by the bigger disc area. It definitely looks very 'planted' in the air, like you can sense the weight and inertia of it. There was very little wind Saturday but I suspect if it was gusty you'd see more difference over a light 700.
                              • I had a fantastic day again at sunny Milton Keynes. Thank goodness for the oak tree which shaded my pit table nicely.
                                The wind was light, from the North West. I had five flights with the 700, still trying to become consistent with stall turns.
                                I had 12 flights with the foamy. I have at last got it trimmed well and it was performing brilliantly. We usually had five foamies in the air together. Mine collided with that of our chairman Kevin but almost no damage was done to either.
                                PS. MK has vacancies for new members. No joining fee at the moment.
