WTF!! Lipo fail.
  • #31
    Thanks Ash, I will give him a call now and hopefully get this sorted out.
    I love being this lucky
    Matt
    • #32
      If the pack is working fine with the 500 ESC then clearly the Jazz had a wobbler, I'm not sure how a pack could toast an ESC unless it was polarity reversed.......in which case it wouldn't spool up, would just do the magic smoke immediatley.
      Sponsored by CSM, Optifuel
      Your RC Heli World
      • #33
        It's a weird one. Jazz was fine on his 450. Was fine on the Outrage previously using a 3s pack just went belly up on 6s. The 500 ESC is quite happy with the current setup as well so the packs are fine.
        Phil
        • #34
          sounds like a warranty replacement to me from Kontronic.
          Your RC Heli World
          • #35
            I think it is on it's way back to it's UK source as we speak...
            Phil
            • #36
              Apologies for the thread hijack
              Just one more quickie for Ash
              Is the Hobby Wing ESC a fair option instead as the 500 ESC is a bit large. £30 seems blooming cheap!! Is the BEC OK bearing in mind it will be driving 3x5065's and a digital on the tail as well?
              Phil
              • #37
                just had a thought, when you plug the batteries into the cellpro is the cellpro showing the voltage for every cell?
                Your RC Heli World
                • #38
                  The hobbywing has been fine on both Ade and Trev's machine. However, it doesn't really do 'slow spoolup' and neither Trev or Ade are using all digitals. That said the BEC should be ok as it's rated to 2A I believe.
                  Your RC Heli World
                  • #39
                    No the cellpro does not show the full six cells, only 5.
                    • #40
                      hmm, interesting. It shouldn't do that, it should show 6. I have a suspicion the balance board may not be charging all six cells.
                      Tell me, when you charge are you charging using balance lead only or balance lead and power lead?
                      Your RC Heli World
                      • #41
                        Just the balance leads.
                        • #42
                          hmm, I have a horrible feeling the charger is only charging 5 cells as without the power lead connection it wouldn't complain that there is a voltage mismatch. ie. it wouldn't see that the pack has more than 5 cells due to the overall voltage being too high.
                          So if you put the pack on charge do you see it just charging 5 cells, ie. it doesn't error, it just charges 5 cells and doesn't say anything about a sixth cell?
                          Your RC Heli World
                          • #43
                            Correct. No error messages, just chargers with 5c info.
                            I could not tell you if this was the case when first charge was applied though.
                            • #44
                              OK, just as a test, please charge the pack to completion, then put it on the Align checker. I'll bet all 5 cells got to 4.2V and the 6th cell doesn't move and stays at 2.7 or whatever it is currently. If so I think we found the problem. Put it on the Align checker first to note the 6th cells voltage.
                              As the Align checker is seeing 6 cells we can rule out a dodgy balance lead, so I think something is wrong at the balance board / charger end.
                              Your RC Heli World
                              • #45
                                On charge now. Cell 6@2.88V
                                Your on to something, your good you are
