my own understanding for it is if you use the atv it limits how far the servo can physically travel but if you use dr the servo knows it can still goto full travel if it has to under high load moves......if it works or not i'm not sure but it kind of makes sense but it doesn't at the same time as you would think if your atv is at 100 and your dr is at 80 then it's only going to move to the 80 even if the tail demands more it might not goto full travel but i assume this is the reason for it IF indeed it is correct.
i have thought about it before and one would assume that because you setup the travel limits in the gyro amp then the gyro knows the servo can move that far if it has to keep the hold even though the radio won't allow it if you see what i mean.
perhaps someone will know for certain but thats what i have always done and adjusted dr.
