remove the tail hub and blade assemble off your x50 and try it on the rappy
no cost envolved to replace the parts
then try the rappy parts on the x50
and see what happens
and yes you can and very often get tail blades out of balance
the other problem with tail blades is the mounting hole goes oval and this can cause the one blade to run in a bigger circle than the other
