I was looking for this info before have now found it on helidirect.
Head:
Frame:
Tail System:
Canopy (combo kits)
Specifications: Height: 378mmWidth 203mm
Main Rotor Blade Size 600-630mm
Main Rotor Diameter: 1355mm -1415mm
Tail Blade Length: 95mm
Tail Rotor Diameter: 250mm
Main Gear ratio: 8.6:1 (8.8:1 Optional)
Tail Rotor Ratio 4.583:1
Approximate Flying Weight with Fuel: 3.6kg /7.936 Lbs. (depending on equipment used)
Head:
- Fully adjustable head allowing multiple setups from high stability to maximum agility making it perfect for the beginner to advanced pilot.
- CNC 7075-T651 American alloy on critical head support parts requiring ultra rigidity.
- CNC 6061-T651 American alloy for head parts requiring stability.
- Dual ball raced seesaw support in center hub.
- Dual ball raced radius arms for precision control.
- Extra long washout base for increased lever stability.
- Dual ball raced 120/140 CCPM swash plate.
- Achievable pitch range of +15/-15 degrees of pitch.
- High quality screw hardware.
- 10mm Hollow hardened main shaft.
- 8mm Spindle shaft.
- Stainless steel 4.75mm OD Linkage balls.
- One piece dampers.
Frame:
- Ultra compact frame technology for superior frame rigidity.
- CNC 6061-T651 American alloy main shaft bearing blocks and mechanics.
- High quality fiber reinforced injection molded plastics.
- Multiple Electronic placement options.
- Adjustable servo mounts for various size and brand servos.
- Ultra large clutch design to maximize engine output.
- Self centering clutch hub.
- Adjustable drive train for optional 8.8:1 gear ratio.
- Designed with new larger displacement 50 class engines in mind.
- Ultra high strength injection molded drive gears.
- Zero pitch alignment points for easy head setup.
- High CFM fan and shroud design for maximum cooling.
- Optimal servo positions for increased accuracy in control.
- Break-away canopy tabs.
- Component positions mounted high in frame enhancing axial CG for improved 3D reactions.
- Optional mounting position for in flight fuel needle trim servo.
- High capacity fuel tank.
Tail System:
- Extend boom length for improved forward flight tracking and superior tail authority in extreme 3D conditions.
- 16 Ball bearing tail pitch control system for smooth precise control.
- Torque tube design for efficiency.
- Ultra high strength Injection molded torque tube gears.
- High quality carbon fiber 95mm tail blades.
Canopy (combo kits)
- Aerodynamically formed canopy shape for enhanced flight characteristics.
- Light weight construction fiberglass composites.
- High quality Canomod painted canopy.
