If the Status lights not changing then you don't have channel 7 correctly assigned.
Waht values do you have in gyro settings. Not sure on DX8 if the HH and Rate are both 0-100% or if one should be above 50% and the other below 50%.
I always use gyro end points to set gyro rates rather than gyro function in radio.
