Not a happy bunny at all!!
  • Not a happy bunny at all!!
    So been having problems with static hits screwing up my 720. So I rerouted the gyro wires just to see if it would make a difference. pop out into the garden to spool up and see...then this happens
    Phil
    What happened there Phil
    Looks bad.
    I assume its the Align SC?
    sigpicx2
    Airskipper 50 - For sale
      the magic smoke has escaped.
      Sponsored by CSM, Optifuel
      Your RC Heli World
        Yeah it is
        Dunno.
        Spooled up in normal, headspeed starts to pick up, flick to ST1 and it slowed and then caught fire
        Phil
          I noticed, the house stinks of it now
          Phil
            Phil
            I know this may not be the ideal time, but I have a brand new Align 60A ESC that I can let you have at half of the new price (£30), although after that experience you may want to try a different make!!
            Russ
            Cheers Russ
            x4 Eddie Gold Stars!
              Cheers Russ.
              I've just taken the ESC to my LHS and they will send it back.
              They have given me a Synergy 60A for now as it normally takes 6 months for Robbe to sort out Align returns
              So for now I'm sorted
              Phil
                too many of these do this. Not good.
                All the best
                Tony.
                  Gutted for you. Least it didn't happen in flight.
                  I do the same as you and select idle-up on the ground.
                  Oliver Crawford - Align 12S T-rex 600e, Align 610 x3, Spartan 760, tail Align 620, Scorpion 4025-630 KV, Bec pro, Castle Creations HV 80A ice.
                  Align T-rex 700e, Align 610 x3, 3g, Spartan 760,Align 650, Bec pro, Castle Creations HV 110A.
                    Originally posted by Bigbellypopper View Post
                    Phil
                    Russ
                    Russ.
                    I'd be happy to give you £30 plus postage for the esc if its for sale.
                      I flick into idle up in order to spool up, that way you save putting a big current spike through it at switch over.
                      Your RC Heli World
                        Just started doing the same here.
                        Normal mode is almost unused on my set now.
                          its now looking like its taken out my Rx to some extent as well Either that or all my cyclic servos as the only thing now working appears to be the tail servo
                          Phil
                            I do on my 450 but that has a proper ESC fitted I still don't fully trust Align stuff to do as its told!!
                            Phil
                              WOW, People still use Align ESC's, blimey.
                              Clones are bad
                              .... that includes Align ones
