Check that all of the links are in place between the servos and the swash, the swash and the mixing arms and the mixing arms and the blade grips. Also check the radius arms are connected between the swash and the washout arms and the links up to the flybar cage.
p.s. you can buy a new antenna.
pps. If you are getting annoyed, now's a good time to call it a night and have another crack at it in the morning.
