OK I now have Rudder control, all thats messed up now if the alerion which is REV, and as I said before when I Norm it it messes the mix up with the three servo's
I need a big favour from someone please
Plus 3 Eddie Gold Stars, yay!
All the throttle curves are OK apart from the last one on the list which is THS 100% and my TX is showing T2S 80% I'm having trouble changing that to THS for some reason?
Correction the THS is completely missing from that block of three settings?Last edited by cambs flyer; 11-05-2008, 03:28 PM.sigpicWayne AKA OB1
OK, the TX is now charging batt is very low, but with the Aileron control does this have to be in reverse or normal mode, as I have reverse and all seems to work peachie, the moment I "norm" it the lot goes cuckoo, and back to square one.
And the THS setting has disappeared out of that three digit set.
I feel so near to correcting it but so far at the same time......
sigpicWayne AKA OB1
Can't anyone help me from this point onwards.
sigpicWayne AKA OB1
OK just done a test spin up, how can I sum it up, total failure, everythings back to front, even at low head speeds she's clearly all over the place.
None of the above has made a shits worth of difference since last nights abortion.
In a word "bollocks"sigpicWayne AKA OB1
Can't help you pal, but chin up....keep at it. Frustrating or what this hobby!!!!!!!!!!!!Originally posted by cambs flyer View PostOK just done a test spin up, how can I sum it up, total failure, everythings back to front, even at low head speeds she's clearly all over the place.
DavidHappy Landings.
David
Raptor 50. OS50
Mcpx
Blade 130x
Goblin 500
Thanks mate, I'm just ****ed off right now, not knowing how the internal software works to make her fly, and I've spent the best part of the day getting this far only to find out I'm no f&&king closer than I was yesterday when I did thought I'd made some progress.
I know one day I'll laugh about this, but that days isn't this one!sigpicWayne AKA OB1
Sorry Wayne, can't help you - it's all Greek to me
I feel for you bud
Phil OB3
Trex 450SE v2
Walkera 4#3b
DX6i
Phoenix
http://stratfordgliding.co.uk/
...and proud owner of THREE!
right dude sorry im late ill get typing and post shortly and hopefully if you follow, it will get you somewhere close!
Boggy seems to be on the case. Good on him.Originally posted by cambs flyer View PostThanks mate, I'm just ****ed off right now, not knowing how the internal software works to make her fly, and I've spent the best part of the day getting this far only to find out I'm no f&&king closer than I was yesterday when I did thought I'd made some progress.
Just stick at it.
You're much further ahead than you think.
David
Raptor 50. OS50
Mcpx
Blade 130x
Goblin 500
put all switches up or back.
where i type press = 1 press of the wheel
right starting at the first screen when you switch on.
press scroll wheel once
your in adjust list turn scroll wheel right 1 click and press
your in model select scroll to your model and press=downloading will show
it will now default back to model select
scroll right one click and press
your in d.r / expo
scroll right one click=that will highlight airl d/r press and set to 100%flick the right hand d/r switch down and set to 75% then press.
scroll right one click you are now in airl expo
press and set your value(20% is a good start)
flick the switch back up and set your value(20%) then press.
elev dr is now high lighted. press and set your value as above(100%) flick the d/r switch down and set your value (75%)and press
scroll right one click into expo. press and set your value(20%)
flick the switch up set the value (20%) and press
the next menu is rudd leave that at 100% and inh for now
scroll right till list is high lighted in the top right corner-- press once
scroll right one click your in travel adjust.
set every thing to 100% then high light list press and scroll right one click. press and your in sub trim menu. set all to 0 high light list and press. scroll right one click and press your in gyro menu.
now wayne this by now should be getting easier and is where your settings are needed!
set the switch to gyro.
set the first value to your setting(if you dont know it try 65%) set both the same
read through that mate and see if it makes sense if it does post back and ill edit and continue if not BOLLOX my typing is sh!^
lets hope it works tim.
when wayne said his menu's read tn2 and tns etc i knew it would be testy!!
feck me that took fifty minutes!!
Thank you Ron your been a star, I'll have to work out the differences between the wheel menus finder and my two orange up and down buttons on the DX6, but what you've written will help no end.
sigpicWayne AKA OB1
