450 clone build
Press right rudder and the tail output shaft should move along the tail rotor shaft in towards the main tail casing. Push left rudder and the tail output shaft should move along the tail rotor shaft outwards.
You need to ensure that this correct direction of tail servo is setup first before you plug your tail servo into your gyro.
Once you have your tail servo centered and the tail servo arm is at 90 degrees and your tail output shaft is in the centre if the tail rotor shaft, then and only then are you good to plug the tail servo into your gyro.
Also make sure your gyro is sensing in the correct direction. You can check this by pushing the tail to the right ( as you look at the heli from the back with the tail pointing towards you) and the gyro should make the tail output shaft move in towards the tail rotor casing. As if it is trying to input a right rudder command to compensate for the movement of the tail and vice versa if you was to push your tail to the left the movement of the tail output shaft along the rotor shaft would be the opposite to the above.
Grant.
Sent from the future using my iWatch.
Grant.
