450 clone build
  • 450 clone build
    Well I have been looking for a while now at getting a good quality 450 clone kit to build but I wanted it to be as cheap as possible as this heli is only going to be for learning the basics with
    i already have a mcpx and Phoenix so can hover quit well now
    so I have been watching eBay for a cheap kit and I found a mystery 450 v2 kit ( trex 450se v2 clone I think ) the kit is brand new and not built yet and the seller has already got servos gyro esc and motor so everything that is needed to finish I will put up the makes of all the things when it turns up I have done some research on this heli and quality is ment to be realy good
    I already have a spektrum dx6i so I bought an orange r615 rx a turnigy accucel 6 balanced charger an a turnigy 2200 3s battery from hobbyking
    all in I have only spent £87 I will be doing a full build thread while I build the kit up and would also appreciate any input from the people in the no carnt wait to get on with it I have a week off this week so should be able to have the first flight by the end of the week
    Syma s107g
    syma s33
    blabe msrx
    blade mcpx v1
    hubsan x4 v1
    align 450 clone
    spektrum dx6i
    pheonix v3
    Would like to know how it goes best of luck
      Just keep an eye on this thread mate I will put up every step hopefully it might help someone in the future
      Syma s107g
      syma s33
      blabe msrx
      blade mcpx v1
      hubsan x4 v1
      align 450 clone
      spektrum dx6i
      pheonix v3
        Hi
        I will be watching this build should be a good build.
        Do you have any set up tools?
        Rich
        SAB Goblin 700C - Black Nitro
        Flight Log
        THE MEDWAY MASSIVE
        WEBSITE FACEBOOK
          Not as such I am just goin to use the mikey rc videos I will probably buy a pitch gauge aswell
          Syma s107g
          syma s33
          blabe msrx
          blade mcpx v1
          hubsan x4 v1
          align 450 clone
          spektrum dx6i
          pheonix v3
            Hey
            When I first started out I was given a 450 size swash levelling tool by a member on here. If you pm me your address I will send it on to you with a spare pitch gauge to get you started.
            Rich
            Flight Log
            THE MEDWAY MASSIVE
            WEBSITE FACEBOOK
              Thanks very much pm sent
              Syma s107g
              syma s33
              blabe msrx
              blade mcpx v1
              hubsan x4 v1
              align 450 clone
              spektrum dx6i
              pheonix v3
                Yer mate I already have some
                which locktite should I use
                Syma s107g
                syma s33
                blabe msrx
                blade mcpx v1
                hubsan x4 v1
                align 450 clone
                spektrum dx6i
                pheonix v3
                  You dont need to go mad on loctite.
                  Only use blue and clean the screws with alcohol.
                  col
                  TRex 700 V4 DFC 8915'S 8900,BEC PRO,HK3 4035 530,HV120,VXIN
                  TRex 700 V3 DFC 8915'S 8900,BEC PRO,750MX 530,HV120,VXIN
                  TRex 700 V3 FBL 8915'S 8900,BEC PRO,700MX 530,YEP120,AR7200
                  Goblin 500 610'S 8900,Gryphon Bec, 4115-1200,ICE 100,AR7200
                  Goblin 700 May sell
                  TRex 450 Pro 308'S 9257,460MX,Yep40,AR7200
                  TRex 500 Pro DFC 9650'S 9257,500MX,RCE70,AR7200
                  TRex 450 Dominator Stock, Ice 50,AR7200, May sell
                    So let the build begin
                    the servos don't seem the best so will change them in the near future
                    Syma s107g
                    syma s33
                    blabe msrx
                    blade mcpx v1
                    hubsan x4 v1
                    align 450 clone
                    spektrum dx6i
                    pheonix v3
                      Right little bit stuck now could someone tell me what wires go where
                      Rx
                      giro
                      i no one is where the tail servo goes in but where do the others go in the rx
                      and the rc says battery/bind on one and thro on the other I thought thro is throttle but that is the esc isn't it and it would go in the battery one
                      Syma s107g
                      syma s33
                      blabe msrx
                      blade mcpx v1
                      hubsan x4 v1
                      align 450 clone
                      spektrum dx6i
                      pheonix v3
                        The one with the single signal wire will go into the gear slot, the other into rudder and your tail servo plugs into the plug.
                        You will use the gear channel as the gain output from the rx to the gyro.
                        col.
                        Goblin 700 May sell
                          Hi
                          The batt/bind port is for a RX battery pack(you won't use a rx pack) and the bind port to bind it to your transmitter. The throttle is where the ESC plugs into and the ESC lead will supply power to the RX from the main lipo battery.
                          Rich
                          Flight Log
                          THE MEDWAY MASSIVE
                          WEBSITE FACEBOOK
                            Or rite I get ya and the other 3 servos are wrote on
                            Syma s107g
                            syma s33
                            blabe msrx
                            blade mcpx v1
                            hubsan x4 v1
                            align 450 clone
                            spektrum dx6i
                            pheonix v3
                              If you look at the heli from "tail in" the cyclic servos are elevator (channel 3/ele on rx) closest to you, aileron on the right (channel 2/aile on rx) and pitch on the left (channel 6/aux 1 on the rx). I think this is right for spektrum.
                              Rich
                              Flight Log
                              THE MEDWAY MASSIVE
                              WEBSITE FACEBOOK
