Spot on cheers I must admit it has helped a lot I can now fly toward and back just need to master the turns now ha carnt believe how a good tx can help
It's turned up
Mark once you have mastered hovering tail in for as long as YOU choose, not when it gets away, then try tail in but at a 45 deg angle, when you master that do it the opposite handed, you will find one way easier than the other.
Sent from my Nexus 4 using Tapatalk
Just thought I would put a quick vid ov me flying the msrx after 2 weeks could someone tell me if I am progressing ok or realy slowly cheers
Msrx 2 weeks flying - YouTube
i feel I am taking a bit of time to learn to fly this but to be fair it is me first proper heli hahaSyma s107g
syma s33
blabe msrx
blade mcpx v1
hubsan x4 v1
align 450 clone
spektrum dx6i
pheonix v3
Try hands off for as long as you can will only be a second or 2 and see if it always goes left, if it does check your trims are centre, if they are then turn the left swash link up half a turn (antickockwise) until it stops drifting left, if it is that is.
the MSRx looks spot on with that canopy on
