It's turned up
  • #46
    I am with you Mark, I am just getting the hang of hovering now but when I first got my mcpx I constantly hit things with it. Still I am not even close to being able stay hovered in one place just yet. Too heavy on the elevator still but I am way better than I was for sure. Practice practice practice is what I have been told from day one. Good luck from one newbie yo another.
    Sent from my HTC One using Tapatalk
    • #47
      Originally posted by Markmark.123 View Post
      Av got no intension of givin up I want to be flying 450s by the summer haha
      That's thee attitude pal,you will get plenty help on here if needed.
      • #48
        i dont no what the crack is with this heli or if its just me but i had it hovering the other day now after i have changed the swashplate i carnt do it just crash it every time
        as soon as i take off it flyes in all directions it just doesnt seem right i have broke 2 of the things that hold the body on (thank god for superglue) does this sound right and somthing i have just got to learn to deal with or could there be sumthing wrong
        Syma s107g
        syma s33
        blabe msrx
        blade mcpx v1
        hubsan x4 v1
        align 450 clone
        spektrum dx6i
        pheonix v3
        • #49
          Breaking the things that hold the body on sounds right They come off the MSRx very easily.
          Did you adjust any of the servo arm lengths when changing the swashplate?
          Does the swashplate look level when you power up the heli with throttle hold on and move the collective up and down with the cyclic stick left in the centre?
          If the swashplate isn't level it will dart about on take off.
          • #50
            well looks like i have just been a complete idiot and getting wound up for nothing. I have spent the last hour reading threads about the problem when one of them mentioned letting the giro set as when you conect the batery you only have 2 seconds to put it on the flat so i conected the batery while it was on the edge of the table waited for the blue light then put it together set it down on the floor and guess what it took off and i hoverd it for about a minute then set it back down perfect
            well it just shows somthing simple can mess with so much
            Syma s107g
            syma s33
            blabe msrx
            blade mcpx v1
            hubsan x4 v1
            align 450 clone
            spektrum dx6i
            pheonix v3
            • #51
              That's right, tern the radio on first then connect the battery to the heli put the heli down on a level flat surface and wait a couple of seconds for giro to set its self level,and a way you go,clad you got it sorted you idiotLOL
              get yourself a hotglue gun from one of those 1£ shops put blobs of hot glue round the roots of your canopy supports it may stiffen them up a wee bit
              • #52
                That's a good idea once I stop crashing all the time I will buy a replacement main frame and canopy then it will be as good as new
                Syma s107g
                syma s33
                blabe msrx
                blade mcpx v1
                hubsan x4 v1
                align 450 clone
                spektrum dx6i
                pheonix v3
                • #53
                  Right next question haha
                  when I get the msrx to hover and try and turn using the rudder it shoots faward is there a reason for this or something I have to counter act
                  Syma s107g
                  syma s33
                  blabe msrx
                  blade mcpx v1
                  hubsan x4 v1
                  align 450 clone
                  spektrum dx6i
                  pheonix v3
                  • #54
                    Just checking ... you know the controls are different to the 3-chan co-ax you have? Rudder is the left stick ...
                    • #55
                      Yer on the left stick
                      Syma s107g
                      syma s33
                      blabe msrx
                      blade mcpx v1
                      hubsan x4 v1
                      align 450 clone
                      spektrum dx6i
                      pheonix v3
                      • #56
                        Then no, in all honestly - rudder input shouldn't make the heli shoot off anywhere. Perhaps you are unknowingly moving the cyclic as you move the rudder?
                        • #57
                          Check out this thread from 2012, Tom covers this issue http://www.rcheliaddict.co.uk/e-flit...teraction.html
                          • #58
                            That's a known issue with the early AS3X firmware on the msrx that levels the swash on rudder input. I suppose it could be related, but Mark is describing the sort of opposite behaviour - ie. level swash moving off-level from rudder input. Perhaps if the rudder isn't level in the first place - it could be the same thing ???
                            • #59
                              As I understood it, if you didn't level the swash prior to flying by adjusting the servo link lengths then once in the air the AS3X adjusts the servos to level the swash keeping the heli stationary.
                              When rudder is applied the bug causes the servos to be centred moving the swash off level causing what Mark is seeing.
                              Have I got that wrong?
                              • #60
                                Not sure TBH! But sounds possible. Mark - is the swash level before take off? (aileron and elevator)
