Theres one!!!
  • #31
    Yes in all flight modes Nick, I found it lazy to start with and indirect. I would 0 the expos in the Vortex and then add it in the Tx to your liking
    That's the best way for me i think
    • #32
      Which servo?.....Is this a throttle servo im not using?...where is the setting.
      Although i have been through the whole lot it's easy to get lost through thinking TOO much lol.
      When using an ESC plugged into SV5 even though you are not using it drive a servo you need to set it analogue servo type. There is a FAQ on the Spartan website.
      Member of Mk Heli Club
      • #33
        This one?
        Spartan RC
        • #34
          That'll be the one.
          Blimey, my previous post barely makes any sense at all having just read it again. lol.
          • #35
            Originally posted by Andy from Sandy View Post
            That'll be the one.
            Now you say,i read it 10 times before it half sunk in lol
            All done now,it was a painful wait with it all hanging off the heli,i needed some double sided taping to be done,part of the build process i normally enjoy
            Well,heres how it looks
ID:	1875631Click image for larger version
            • #36
              It is hard to see but do you have the slave lead from the ESC plugged in?
              • #37
                Yes,click on pic then click again to magnify
                Hot glue at the ready!
                • #38
                  Good move.
                  • #39
                    Should i use the thicker black sensor pad?
                    • #40
                      So far on all my models with the v-bar I have used the Ming Yang aka Ripmax servo tape and I have had no issues. I think it is best to firm mount the sensor first and see how it goes. Soft mounting could allow the sensor to move around in hard maneuver.
                      • #41
                        I have some ming yang here,will use that.
                        • #42
                          That's what I used to mount my sensor
                          Cheers Matt
                          • #43
                            Be prepared to relocate the sensor, sometimes it is required. The top shelf might be better and it is no big deal to not have the datapod permanently mounted.
                            • #44
                              Pod is there temporarily.Think Mattie used the bottom shelf,he flew his today
                              • #45
                                Yeah, mine is mounted on the bottom shelf. The supplied thin tape didnt work to well as its mounted across the join of the frames. The Ming yang worked much better
                                Cheers Matt
