Originally posted by Nick_C
View Post
Align 3gx Help
From memory in pc software to adjust the cyclic limits would be the the first set of parameters, two are for rates & the other two for cyclic limiting.Today's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
- Flickr Through My Pictures.
The other thing that puzzle me is when you set up cyclic in dir your cyclic degrees for aile & elev should be about 12/13 degrees then in PC software you take the cyclic down to 8/9 & adjust cyclic rates for your style of flight.
Could be worth default tx setup & start new model as 3gx has its own memory & doesn't see changes in tx once you've done your first tx setup, I think 3gx mentions the only tx adjustments you can use once you've gone through dir.Last edited by tourerjim; 22-12-2015, 08:30 AM.Today's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
Hey Buddy.Originally posted by Nick_C View PostIts a Trex 500pro Ian,swashplate values are
Ail +47%
Ele +47%
Pitch +37%
Ah cool, those figures look about the norm for 99% of 3GX setups. I was just curious to know in case they ended up being quite low, which I've seen with the 600EFL's for example.
The first question I suppose is did you hit write settings ocne you'd moved the limit sliders? You may just need to move them further.
IanIan Contessa
Coolice Power Supplies
I did hit the write setting once slider moved lower on elevator travel limit,made no differenceOriginally posted by coolice View PostHey Buddy.
Ian- Trex 700N RMJ,msh brain
- Goblin 700 black thunder sport,vbar Neo
- Trex 700L Dfc,vbar Night Flyer
- Trex 700x,Vbar Neo
- Goblin 570,msh brain
- Goblin 380 kse,msh brain
- NeXt sim and DX9 and Vcontrol
I am already on inside hole on arm,is it worth me posting a vid of it?- Trex 700N RMJ,msh brain
Hey Nick.
What value are you at with the PC software and still getting over driving?
On other forums it appears with V5 the overall travel ranges were increased, so it may be that the limit sliders need to be reduced more than expected to work effectively.
IanLast edited by coolice; 23-12-2015, 02:05 PM.Ian Contessa
Hi Ian,Originally posted by coolice View PostHey Nick.
Ian
Am at 70% on the elevator limit,if you reduce that in software it still binds and doesnt reduce limits at all- Trex 700N RMJ,msh brain
