Hi
I'm new on the forum looking for some help with a my new Align MR25. Just ordered this from fast-Lad with a Spektrum satellite receiver to go with my DX7 (original version). What ever I do I cannot get it to work. I have created a new Aircraft model on the transmitter. When you turn the MR24 on it goes into what I think is bind mode, yellow lights flash quickly. I can link the APP to the model ok and set the correct receiver type but when you move the sticks you get nothing. The motor test works so there is life there but no link from the transmitter on any channel. I've tried turning the transmitter on in bind mode, not in bind mode, first and last but nothing.
I have also tried connecting the satellite receiver to an AR7000, binding it (which works perfectly fine) and then connected to the MR25. When I do this the bind light comes on solid (most times) but still cannot get the MR25 to recognise any movement on the sticks or switches.
I have also tried 2 other receivers an AR7000 and AR6110, when these are connected I do get them to bind when the MR25 starts up. I turn the MR25 on first then the transmitter in bind mode. I can get the MR25 to see these and they appear to work ok as I can complete the setup without any problems. I am able to calibrate the sticks and set switch positions no problem, HOWEVER, as soon as I turn the MR25 & transmitter off and back on again, it goes back into bind mode. It has lost the BIND from the previous time however when I do bind it again all the settings in the app are still there.
Surely this cannot be correct that you have to bind the receiver every time and turn on the transmitter in bind mode?? I have read a comment on here there is a problem with Spektrum receivers, has any one else seen this or any ideas? I have been trying every combination now for 3 days!
many thanks
Dave
many thanks
Dave
