I have a PCM9XII( with 2.4 module) and I have been able to configure and set the correct operation of all the channels except the Gyro. The only channel not been used on the RX is the Gear channel. But I cant seem to be able to change the TX so that I can set the values on the Gear channel to allow me to switch between HH and normal and set the gain for each mode.
Any ideas or pointer please, I cant be the only one using a PCM9XII with an AR6100e RX.
I done a little reading and starting to think I may need a 7 ch receiver to set this up properly, but thought i would ask before spending the money.
Im a little surprised if it cant be done as I brought this second hand and it came with settings for a DX6, which is obviously different to my PCM9XII. I would of thought i could configure it to be like a DX6, but cant seem to work out how.
Many thanks for any advice.
Anthony
Anthony
