hello just wanted to let u guys know about the DX8 signal lost warning, yesterday when i was flying my heli went in and i didnt know y at the time i had a 600 fitted with the telemerty system and it was working well at the time but when i was flying not to far away from me the heli lost signal and went into fail safe and came crashing to the ground thank god the crash was not to bad.
At the time i didnt know what caused the crash and y it went into fail safe but when i had a look at the flight data log i had 133 F and 1 H i didnt know what that ment so i went home and did some reading and found out what it all mean, so what i discovered is that up to 20 F is ok but any thing over is bad and 1 H is not good at all so that y the heli went in to fail safe because it lost signal so after the info that i got they recon that carbon fiber can couse the problem and also where u have the arials positioned so i repositioned the RX with the arial pointing dowm( i stuck it to the nose) and i put the sat arial on the left side with the arial across.
Went out and tried it today and it worked well i had 10 F and 0 H witch is very good as long as its below 20 F that good any thing over is bad and even 1 H is really bad so if any one else out there thats havinf this problem try and repositioned the arial and i also set a warning at 10 F and 1 H
