Heya All,
A bit of a waird problem here so here goes,
Well i run my sticks pretty loose, probably not as loose as some people, but loose so the centering force of the spring is not that much, but it still centers fine, but when i was setting up my cyclock i noticed that it would not sense the center stick on Ailerone, Hmm?
So i went into the servo monitor and sure enough its just a click or two trim off center, i wiggle the stick and its a bit better but mostly its not.
So I disassemble the Tx backcase and increased the stick tension so now it centers alot sharper, But these seems to have made it worse,
For you to get an idea of what its like if you center one of your trim controls and click it either left or right 3 times thats how far it is off center.
So anyway, Im a bit stumped. i go trough all the mixes and there are non set, check everything including expo since that can make an effect and it still does it,
So i launch up my Sim Model Memory on the Transmitter and it perfectly centers fine? im confused, switched back and the same issue occurrs go back to the Sim Model memory and its fine.
Has anyone had this issue before?
Regards
Callum
Regards
Callum
