Transition to DX7
  • Transition to DX7
    Well ive purchased a new Dx7 with ar7000. I there anything I should be aware off in the transition of my models to the new dx7 from a Dx6i or it is the same menu?
    Goblin 700
    Should be the same
    you have 2 Dx7's ?
    Do you want a third thinking of selling mine
    only thing is it Mode 1
    Cheers Paul
    Citizen #42
      The same as what? A DX6i?
      Martin
        I'm afraid you need to setup a new model and setup the model afresh.
        You cannot copy the settings over. They may be slightly out.
        Jaco
        Outrage Velocity 50 FBL - OS55 - Align DS610, AR7200BX + DS650, MGP, Perfect Regulators Igniter Push Button Glow and Flighttech 8A regulator
        T-Rex 600NSP FBL - OS50 - Align DS620, AR7200BX + DS650, MGP, SwitchGlo and Ely.Q reg
        T-Rex 450SE V2 with CC45 esc
        sigpic Proud owner of 2(Two) EGS!
          sorry just re read that and missed off dx6i
          Goblin 700
            The menu is differant but should be easy
            Cheers Paul
            Citizen #42
              is the gyro gain the same?
              Goblin 700
                OK - well, what I will say is that, having gone from a DX6i to a DX7, the changes were, IMHO, quite daunting. Furthermore I found that I had to completely re-do my pitch curves to get the same physical pitch on the heli.
                See here: http://www.rcheliaddict.co.uk/transm...tml#post302796
                Start with the DX7 from scratch. Assume that none of your DX6i settings will work.
                Martin
                  Yes the gyro gain will be similar.
                  Jaco
                    thanks Mart, was hoping I could just transfer across the values, bind and be all set but alas it isnt so.
                    Goblin 700
                      What gain are you running in the Dx6i ?
                      My GY401's tend to be in the low to mid 70's but a few others are higher.
                        All mine are running in the high 60s
                        Goblin 700
                          +1 - I found exactly the same going from DX6i to DX7.
                          Brian
                          More enthusiasm than skill
                          And proud recipient of 3x sigpic
                            I suspect you'll need to have it higher on the DX7.
                            It depends on if you have it set to gear using the travel adjust or to gyro which will be an actual gain setting.
                            A while back someone did some setup work on one of my 450's using a DX6i and I'm pretty sure I had to bump the gain setting from like 78 to almost 90 on this particular gyro (Gulang 700).
                            The safest bet is bump it up a bit and keep raising it til you start to get a fast wag and then back it down.
                              cheers Sheryl, might have to get you to run through when we are next down the field
                              Goblin 700
