Hoping the DX7 experts are reading this -- with the Rx's installed in the Trex600 -- If needed again how do I go through the Binding Proceedure when with this installation I don't use the stock switch harness?
Tried using the Binding Plug into channel 7 of the main rx but this did not work . So used an external nicad via the stock switch lead.
Check pic and comment on Rx positions - worried about the carbon side frames blanking the signal.
Dave
Dave
- in the end I bought 3- will just use velcro and transfer as required, I'll say this though, after my 1st flight with the system in a mini funtana,could not believe how locked in it feels- the slightest touch shows an instant response,probably will tighten up the stick's and add a bit of expo,otherwise,its the dogs nuts!!!- next few days I'll try it in my trex 450se..
