Might be worth giving macgregor a ring. There is also the graupner MX22 which is a 9x case with different software.
I am pretty sure that the different versions you speak of is purely switch position and throttle ratchet.
one thing i forgot to mention was that with the JR you can transfer models through the buddy lead. However you can only transfer from 9x2 to 9x2. not to the older 9x or an imported 9x2 to a UK 9x2
You can buy the data xchange software that will pull models off and onto all JR txs. Mark Christy is the man for that.
Futaba you have to buy a campac but even then you can only transfer to/from radios of the same type.
Ade
Ade
