ar7000, dx6i, and flashing lights
  • ar7000, dx6i, and flashing lights
    well sometimes they do, and some times they dont, it wierd, any ideas? faulty? wrong position?
    The flashing lights mean that the rx lost power and got it back again.
    If you disconnect the rx and reconnect it, but leave the tx switched on all the time - then you get the flashing lights becuase it thinks it got a powwer problem.
    If you always switch both rx and tx off and switch them both on again, you will not get the flashing lights and the lights will comeon solid.
    If you have a power supply to the receiver that is not up to the job, then when you take off with the led solid, it might be flashing when you land. Meaning it was close to failing during the flight, or in fact it did fail momentarily. The flashing lights are a warning of this problem.
      it on my outrage g5, so it runs from the battery, maybe its cost the deans are abit tight still?? a quck on/off as i connect them?
        pronbably. I have he same prob with my 500 trying to get the deans in clean.
          It happened to me. Turned out the tx was too close. If you move it away it's ok. It mentions it in the manual but I hadn't noticed it. Once it starts flashing you have to cycle the tx to reset it. It is also a fault indicator as the others said.
          Blade 130-X, MSR, MSRX
          Phoenix Sim
            yes same thing kept me puzzled for some time untill wayne(cambs flyer) pointed me in the right direction ,moved the trannie away and it has'nt happend again.
            Trex 550e dfc :-)
            t-rex 450s x2 /Raptor 50
            kyosho spree small plank
            bogey combat plank x2 woop
            http://www.cuffleymfc.co.uk
              you know what, i tried it just now, and your all right!! lol!!! move the dam thing away when you plug up!!!!!! lol!! now i feel stupid!! lol!!!
                and just to add more insult to myself, what you mean, cycle the tx? you mean start again?
                  I don't know what I did to stop the lights flashing. I usually start up the rx first then I know that my gyro will initialise to the bound value stored in the rx and the lights don't come on. If I start the tx first the gyro doesn't seem to start the same because I think the rx output changes from the bound rx values to the current tx ones while the gyro is initialising.
                  All I did was read the instructions and I didn't believe them until it worked.
                  I was really convinced the problem was the sparks coming from connecting the Deans together.
                  Phoenix Sim
                    Connecting the rx (and therefore the esc and motor) first is bad practise as you are not in control of the heli.
                    I know that the esc should prevent the motor from spinning up but you should always be in full control of your model at all times.
                    Switch the TX on first followed by the Rx never the other way round.
                    It is also in the BMFA guidelines/rules.
                      well thats what i thought, i would never plug the battery in with out the tx turned on, did once when i 1st started, nothing happened thank god, but when i relised what i did, i rolled away!!!! lol!!! just in case!!! lol!!!
                        i am with adrain on this one although it does say it dosent matter witch one you switch on first in the manual so i just make sure the tranny is at least 4ft away before i switch on the rx having first switching the tx.
                        Trex 550e dfc :-)
                          well the thought of my heli with power and no control is scary!!!
                            The BMFA part is the killer; but from a technical perspective I'd happilly argue that with DSM2 it's safer to power up the Rx before the Tx.
                            A correctly functioning DSM2 Rx won't send a pulse to the ESC (at all) until it's connected to a Tx.
                            If the Rx isn't functioning correctly, all bets are off anyway.
                            Yes, it's th@ tw@ Scallyb@...
