perfect fit in the case of my 9x2 so will slot straight in. comes with connectors for both JR and Futaba. I get 12hrs "on" time.
Ade
www.accurc.com adrian@accurc.com
This is an apple free zone
I've been using a lipo in my 9X2 for a good while now with no problems although I do leave the transmitter to stand for an hour or so before turning it on to let the voltage drop a little.
Steve H
as im on JR i can leave the battery in the tx and plug into the futaba connector. Spektrum is the same.
the futaba connector is a servo connector which are pretty tough.
the extra voltage is no issue. a fully charged nimh in good nick will sit at 12v for a short time. A li-po peaks at 12.6 but that soon drops to just under 12.
Ade
I've bridged the diode in the charge circuit on my PCM9X2 so I charge through the charge socket to avoid disconnecting and reconnecting the battery. I take the battery cover off and use a passive balancer on the balance tap although it's always in balance as the current drain in use is tiny. My charger also has a temperature sensor which I put on the battery so if there was a problem and the battery started to get warm the charger would cut off.
Steve H
