Futaba 7c FAAST 2.4GHz - Battery Drain
  • Futaba 7c FAAST 2.4GHz - Battery Drain
    Hi
    I have got my 2.4GHz 7c set and its great apart from the fact that the stock nicad pack that came with it seems to have shocking performance. I can have the set turned on for literally 20 mins from a charge until the low voltage alarm sets off. Is this a known problem at all or have i just got a dud battery pack?
    thanks
    If the battery pack has been fully charged then it sounds like a duff pack.
    How has the pack been charged?
    | 3D Championship
      well i charged it for a bood 6-8 hours so i presume its fully charged.
      It gets its charge from the tx charger that came with the kit so maybe its just no good.
        That battery needs about a 15 hour charge. (It says so on the battery. Remove the back cover and see.) Leave it on overnight. The screen should display about 11v from fully charged.
        6-8 hours should give you longer than 20 mins though it wont be fully charged which could be your problem. Give it a full charge tonight and it should be fine tomorrow. If not, you have a problem.
          thanks both - i'll leave it on overnight to see where we are at then.
