6v 5 cell in DX7?
  • 6v 5 cell in DX7?
    Hi, my Spektrum DX7 came with a 4.8v 4 cell pack, would it be ok to use a 6v 5 cell instead? the battery compartment is big enough
    They make a 2s Lipo for it (8.4V fully charged) so there should be no problems with voltage. The low volt alarm would need changing though, and I don't know if there is a setting for 5 cell ni-mh.
    Get the 2S lipo if you can. Pulse, Gens Ace and Turnigy do one for reasonable money and they last for months of weekend use without needing a recharge.
      You got a link to said 2s Lipo for it (8.4V fully charged) pretty please
        Gens ace 4000mAh 7.4V tx 2S1P Lipo DX7S/DX8 GA-B-TX-4000-2S1P
        Here you go.
        These are a great buy.
        Rich
        SAB Goblin 700C - Black Nitro
        Flight Log
        THE MEDWAY MASSIVE
        WEBSITE FACEBOOK
          Nice, just ordered said item, I can still use the spekky TX charger thats plugs into the side with battery in place yes?
            I have a DX8 and I can use the supplied charger to charge the Tx with both types of batteries installed. I believe the DX7 is the same but someone should be able to confirm...
            Rich
            Flight Log
            THE MEDWAY MASSIVE
            WEBSITE FACEBOOK
              Hi
              Is your Tx a DX7s? (the new model?). If it is yes you can use the supplied wall charger to charge the LiPo.
              Rich
              Flight Log
              THE MEDWAY MASSIVE
              WEBSITE FACEBOOK
                Cabbie10 if your is a dx7, as your first post. It would have come with a 8 cell 9.6v Nimh pack not a 4.8v pack like supplied with a dx7s which you can use a 2cell lipo as suggested. And use the supplied dx7s charger with
                Santander Factory Team
                Proud wearer of 5 x EGS
                  As long as we are talking about the DX7S not the DX7 then yes.
                  The charge circuit in the radio was really built for the lipo rather than the NiMH it ships with, and will actually turn off when the charge is complete.
                  Don't forget to change the low voltage alarm, it makes no difference to the charging though, that is independent.
                    Yes its the DX7s, thanks for help
                      Kool then use the suggested 4000mah lipo will last for months
                        Ordered it
                        Dude check out the new swing arm and finished blade
                        https://www.youtube.com/watch?v=uJWdR3kzHqs
                        Being naughty
                        https://www.youtube.com/watch?v=WqNLObINYdE
                          What should I change it too? it's on 4.3v
                            Pretty sure with the DX8, when you change the battery type to 'Lipo' it will change the low voltage cut-off at the same time.
