2.4ghz
  • 2.4ghz
    Just reading through the BMFA hand book and noticed on page 68, headed "The 2.4ghz band", it recommends this band is only used indoors due to poor range issues! I have been led to believe this type of radio equipment was the bees knees, and cuts out glitch issues also.
    I do not know enough about this to make my own guestimations on what is better, but is this a problem or not? Up until now I thought I had made a mistake when I purchased a 35mhz set and considered changing to 2.4gig to solve my glitch issues.
    I only fly a small heli so it never really gets too far away, so maybe it would be ok?
    JAMIE,
    -Mini Titan e325-
    Sonix cnc head & tail rotor
    GY401 & HDS 577 servo
    HS65mg's
    CY radix blades
    scorpion hk2221-8 motor & 55a esc
    Spektrum DX7-goodbye glitches
    Think that must be old news in the manual that needs updating?
    they say low range due to max power of 10mw, but I think 2.4Ghz now work at 100mw and have No range problems, except the DX6, which is a lower range park flyer, although DX6i has full range....
    anyone feel to correct me if I'm wrong?
    Simon
      I use 2.4 on all of my stuff including my planks which get a fair distance away with no loss of anything, if you've got a good 35Mhz set though keep hold of it 'til it breaks and then upgrade, that was my reason and it does work out quite costly if you've more than a few models.
      Andy
      sigpicX2
