Buffer pack/Backup guard
    CC don't recommend it for the reasons mentioned above. But I use a Talon90 + OptiGuard on my G500 and it works fine!
      CC recommend firing the Talon up with 1/2 throttle. Any chance the main motor could fire up?. Or do you keep the throttle at bottom stick?
      Happy Landings.
      David
      Raptor 50. OS50
      Mcpx
      Blade 130x
      Goblin 500
        Never seen that advice, but suspect it's just to stop the ESC arming when you plug it in as it won't arm until it's seen a 0% throttle value.
        I get the same effect by having auto-rotation bailout enabled. So, my throttle-hold value is something like 14%. I plug in with TH enabled and the ESC doesn't arm. It's only until I release throttle hold, and have the left stick fully down that the ESC will finally arm and I can switch to IU1.
          Ah. I have TH at nil. So, if I had say 15% power that would keep the motor running very slowly and not show the ESC zero until TH released?
          Happy Landings.
          David
          Raptor 50. OS50
          Mcpx
          Blade 130x
          Goblin 500
            No. Ordinarily, 15% power would spin the motor (edit: once the ESC was armed - it would need to see a 0% first for this). There's an option in the Talon though for "auto rotation bailout". This creates a dead-band between zero and roughly 16% where the motor doesn't spin.
            The idea is that you can bailout of an auto by releasing TH. Since TH (in this scenario) doesn't send 0%, the ESC understands that it needs to re-spool the rotors quickly, and not use the soft-start it would use from 0%.
              Got it...thanks
              Happy Landings.
              David
              Raptor 50. OS50
              Mcpx
              Blade 130x
              Goblin 500
                NP. See slight edit to my post above ...
