JR 8717 and 8915
  • JR 8717 and 8915
    Are they the same servo, some say yes and some say no. The specs IE voltage but some threads say the same servo
    8717 same but usa aparantily
    JR DS8717 Servo Specifications and Reviews
    Santander Factory Team
    Proud wearer of 5 x EGS
      Yep, that's what I've heard too. My experience is that they work fantastically well, but are quite 'thirsty' for electrical power in flight.
        I had a little mishap in the smog last night and done a servo. The only spare I've got without replacing the whole 3 cyclics is an 8717 to go along with the 8915's. The only disparity I can find is that the voltage is quoted differently between the 2
          JR DS8915 Servo Specifications and Reviews
            I think the fact it states that it's a different number for USA and Europe and that's it is enough for me, cheers Brian
              put usa one on left hand side
                so you should be up and running ASAP then!
                  Saturday I will be back in the air. Nowt like a little mishap for some much needed degreasing and maintenance
                    will we have another video with fire works for the re-maiden flight?
                    Hirobo Turbulence D3
                    1/4 scale Vario Bell 47 G3
                    1/3 scale Vario R22
                    2012 LHC Scale Cup Judge
                      You do maintenance! Wow, perhaps I should give that a try some time!
