Iv read that you can run ds 610s on 8 v can you do the same with a ds 650 and if you can how do you go about it can you just plug your 2s lipo into your vortex/vbar/beast
Ds 610s
Ds 610s
GOBLIN 630 COMP
RAPTOR E700 V2
GAUI X5
GAUI NX5
SPEKTRUM DX9
PHOENIX SIM
I'm a proud member of Http://phoenixrotors.orgTags: None
yep, The servos are only rated at 6v tho, but I have used them on direct lipo with no ill effects before, Just be aware that your warranty will be null and void if using direct lipo instead of regulated 6vSome say my left nipple is the shape of a Raptor canopy.......... And that for fun I chase sheep in wellies 3 sizes too big. All I know is I am 3D Clod
Collector of SAB Goblins
I'm trying to set up my practice machine iv brought a velocity 50 n2 air frame with some spears for £125 witch I thought was a bit of a bargain so I'm trying to build it up cheap as pos iv also got a os55 with the os pipe and vortex i might pinch the servos off of my 600 e pro.i read about that people had ran ds 610s straight from a 2s lipo and thought I could build it a little cheaper but my receiver packs are align batteries they have those red connectors on could I put one of these on http://www.fast-lad.co.uk/store/quan...4-p-15434.html thanksLast edited by Red Devil; 14-04-2013, 07:57 PM.GOBLIN 630 COMP
RAPTOR E700 V2
GAUI X5
GAUI NX5
SPEKTRUM DX9
PHOENIX SIM
I think I should just get one of those 2 in 1 regs for the sake of £30 oddGOBLIN 630 COMP
RAPTOR E700 V2
GAUI X5
GAUI NX5
SPEKTRUM DX9
PHOENIX SIM
Why not get a LiFe battery. The 610 and 650 will be fine. and cheaper than a reg, and WAYYYYYYYYYYYYYYYYY better than the align 2 in 1
Nominal voltage 3 min into first flight with a 2100 pack (2s) is about 6.6 v will drop to about 6.2 under heavy load.SWRCH ,
Oh.. And a Helix 700 Gasser, Hv with SK540.....with SAB HPS head.
that idea sits better say this bat Hyperion Rx Battery Pack LiFe 6.6V 2100mAh 5C HP-FG305-2100-2S but what connectorOriginally posted by Baldie View PostWhy not get a LiFe battery. The 610 and 650 will be fine. and cheaper than a reg, and WAYYYYYYYYYYYYYYYYY better than the align 2 in 1
Nominal voltage 3 min into first flight with a 2100 pack (2s) is about 6.6 v will drop to about 6.2 under heavy load.GOBLIN 630 COMP
RAPTOR E700 V2
GAUI X5
GAUI NX5
SPEKTRUM DX9
PHOENIX SIM
Whichever connector you prefer. I use ec3, then on the "Heli" side, I extend one of the cables, cut it where i want to have the "Switch" and fit bullet connectors.
fully charge it before your first flight.
After your first flight, charge it fully again and note how many mAh you put back.
this will indicate how many flights you can have before charging.
And most LiFe are happy to charge at higher rates than 1c tooSWRCH ,
thanks mateOriginally posted by Baldie View PostWhichever connector you prefer. I use ec3, then on the "Heli" side, I extend one of the cables, cut it where i want to have the "Switch" and fit bullet connectors.
And most LiFe are happy to charge at higher rates than 1c tooGOBLIN 630 COMP
RAPTOR E700 V2
GAUI X5
GAUI NX5
SPEKTRUM DX9
PHOENIX SIM
