GP750 limit settin help!
  • GP750 limit settin help!
    I try to set the limit on left and right, yet it still over travels to the left every time. What am i doing wrong? I hold the setup button, enter setup mode go to limit move the rudder stick to left then right, then press the setup button agian. Just binds on left travel every time. Help would greatly be appricated. Thanks guys
    Synergy e7
    Trex 550 dfc incoming
    trex 450 pro with dfc head for sale
    mcpx bl conversion
    mcpx bl
    I am having a few issues with my 750. I am going to try a rebind. then through the process again. try that first.
    Just remembered, make sure you have NO subtrim or trim on the rudder channel at all
    TDR (in progress)
    SAB Goblin 700
    Vibe 90SG Vibe 500E
    Kalt Baron30
      think you might have to do left then right mate if i remember right
      Gaui x7 lush
      Gobbalin 500
      ALL ON SPEKKY GEAR
      Blade 130x2
      nano
        Put it into limit mode, move stick left then to the right for your travel, then let your rudder stick return to neutral. Wait until gyro comes out of setup mode then test.
        For some reason mine wouldn't set properly unless i let it finish by leaving it alone to come out of setup mode after setting the limits.
        Thanks, Chris
        Avant Aurora
        T-rex 700 LE - BeastX
        T-rex 600 NSP
        Member of ;
        SCHA www.southcheshire.rcheliaddict.co.uk
        BMFC http://byleymfc.webs.com/
          Another tip from the great 'Finless Bob'. Move your rudder left and right, (marking on the rudder control rod with a marker against one of the guides) and mark the rudder control rod just befor it begins to bind on the servo, this way you can just look at the marks when setting the limits knowing how much travel you have got before binding the servo
          Register with Heli Freak if your not already and you will be able to download the tail setup vid, lots to learn on there
          Trex 450 Pro build videos - HeliFreak
          Thanks, Chris
          Avant Aurora
          T-rex 600 NSP
          Member of ;
