Switched on gyro and the servo went hard-over to the servo travel limit. Entered setup mode but I could not adjust the end-point travel in one direction (the other direction I could adjust end-point travel). Thought it might have defaulted to wrong servo type for some reason but was unable to enter servo type menu (was still able to enter config menu).
Checked all endpoints and sub trims were neutral, checked correct channels for rudder and aux, checked gains were sufficient to switch between heading hold and rate.
I did update the firmware before this flight.
The first port of call is to reset the gyro to defaults and see what happens.
Just wondered if anyone else has had this problem?
