Hi I have a F7C tx and I have programed Switch a as the govenor on off switch is this normail or should I program it to the same as the N idle1 and 2 switch?
Align Governer setup
Nick Greening
Trex 600 NSP Yellow and black
Trex 450s CF
Phoenix
Picco Z
http://www.gmfg.org.uk/
Proud owner of an Eddie Gold Star
Tags: None
Try this:
http://www.rcheliaddict.co.uk/showth...eferrerid=6040
I have found that 77% on the tx gives approx 1900rpm headspeed - still experimenting (tomorrow hopefully)Shaun.
Proud owner of an Eddie Gold Star.
T-Rex 450 SE V2, Maniacs, Kontronik Jazz ESC, Microheli Tail
T-Rex 500 CF, DS510's, Maniacs, Torque Tube Tail Drive
T-Rex 600NSP, Maniac 603's
T-Rex 600ESP, Maniac 603's, DS610's
T-Rex 700LE, Maniacs, DS610's, Solid-G/BLS251, ElyQ Reg
Futaba FF7 2.4 GHz
Phoenix Sim
You can programme an on/off switch but I would also programme the gov to work with your idle up switch. E.g normal-off, idle 1 1900, idle 2 2100. The only reason to have an on/off switch is for getting curves close to perfect to assist the governor otherwise I wouldn't use one.
Hope that makes sense and answers your question.
| 3D Championship
Pete,Originally posted by t-rex pedro View PostYou can programme an on/off switch but I would also programme the gov to work with your idle up switch. E.g normal-off, idle 1 1900, idle 2 2100. The only reason to have an on/off switch is for getting curves close to perfect to assist the governor otherwise I wouldn't use one.
What is your IU1 throttle curve like?Shaun.
Futaba FF7 2.4 GHz
Phoenix Sim
Shaun.
Futaba FF7 2.4 GHz
Phoenix Sim
