Has anyone tried these in a 500? Similar speed and torque as a 9257 but with metal gears and cheap too. Also is this a digital servo?
Futaba S9602 Servo High-Speed Mini Air
[S9602] £29.29
FEATURES:
Coreless Motor for Smoother, Stronger Action
Dual Ball Bearing Output Shaft
Metal Gears
Case is Made of Black Plastic
Water Resistant (NOT waterproof)
INCLUDES:
One High Speed Mini Aircraft Servo.
One Servo Accessory Bag (grommets, brass bushings, screws, horns)
SPECS:
Speed: 0.11sec/60 deg @ 4.8V or .09 sec/60 deg @ 6V
Torque: 30 oz-in @ 4.8V or 37 oz-in @ 6V (2.2 kg-cm @ 4.8V or 2.7 kg-cm @ 6V)
Size: 1.4" (35mm) x 0.6" (15mm) x 1.2" (30mm)
Weight: 1.1 oz (31g)
Oli
[S9602] £29.29
FEATURES: Coreless Motor for Smoother, Stronger Action
Metal Gears
INCLUDES:
SPECS:
Oli
