I've just installed some JR 8915's on the cyclics on my 600n. When it came to testing the set up I found I had to reverse the servos in my radio from the original Futaba set up. All installed exactly the same way in the receiver slots. Do JR servos run the opposite way to Futaba? Sounds silly to me but its the only reason I can come up with!!!!!!!
JR Servo reverse?
Yes, they always go the opposite way to Futaba servos. The positive and negative wires are in the opposite positions on the servo lead. The signal wire is in the same place. It's also to same with their Tx charging sockets, which is why you can't use a Futaba charger on a JR Tx.JR Vibe Fifty fb (YS56)
hitecs do pete so maybe??
That sounds misleading to me. If you place a JR and a Futaba servo connector side by side so the smooth side is up and the holes are facing away from you the negative will be the wire to the left. The positive is in the centre and the signal wire is to the right. What you wrote implies if you swap the centre and left hand wire on the JR servo it will work the same as a Futaba one, which it wont because they are in the same position as each other. They go in opposite directions because of the way the signal is interpreted by each company.Originally posted by The Manager View PostYes, they always go the opposite way to Futaba servos. The positive and negative wires are in the opposite positions on the servo lead.
For sure which is why I made no comment. Make mine a double -Originally posted by The Manager View PostThe Tx charge leads don't match.
Servo's are wired the same way around - it's why we can plug them into any receiver...
RobTeam Align, Midland Helicopters, Optifuel, Cyclone Blades, Scorpion Motors, Thunder Power, Savox Servos, JR Propo
| 3D Championship
Hi There
I Have 8915's In My 600 Nitro
I Use A Dsx9
What You Need To Do Is Go Into Into Servo Reverse And Set
Ch2 To Rev
Ch3 To Norm
Ch6 To Norm
Then Go Into Swash Mix And Set Ail & Elev To Both -60% Travel
And You Will Be Done
Any Problems Pm Me
MARK
LOGO 500 V-BAR v5.2
GAUI X4ii
PROTOS 500
MINI PROTOS 6S (stretched )
GAUI X3. 6S
JR DSX12
14SG S-BUS
proud owner of 2 x EGS
www.bmmfc.com
