TAROT ZYX 3 axis help
  • TAROT ZYX 3 axis help
    I just completely had to rebuild my 450pro DFC after crashing last week and need help with the tarot setting up. I've had to change nearly everything on her, Servos, gears, head, shaft, tail boom etc and need to start from scratch to set her up. I'm a little confused with what the manual says " connect to receiver"?? Problem is I only use the tarot and a satellite and not a receiver, do I need to use one to set up or can I just plug servos and esc straight into the unit? That's how is was before and flew rock solid. I've looked for videos on setting up, but the only one on you tube is really confusing as the guy skips bits etc. if anyone has set one up from scratch, please can you go through it step by step for me or send me a link or video how to start. I really want to try and do this myself, rather than taking her to a shop to sort out. Where do I start?
    Align trex 700x brain 2 BT
    SAB Goblin 700 KSE Brain 2 BT
    Trex 600 ESP brain 2
    If it is ZYX, not ZYX-S it can not be connected with satellites as far as it doesn't have s-bus support. If you want use ZYX you need to buy a receiver fot it.
    Roman
    Tarot 250 PRO FBL, Aeolian Motor 3400kv, Aeolian 35A ESC, ZYX-S, Zippy Compact 850mAh x4
    CopterX 450 PRO DFC, Turnigy 2836, YEP-60A, ZYX-S, Zippy Flightmax 2200mAh (40C)
    Skylark Tiny OSD III + LawMate 1.2 GHz FPV
      Thanks for input, but I do run a satellite by its self with and it flys amazingly. It is the zyx, not the s, but just run the unit. I know it sounds strange, but there really isn't a receiver connected, that's what's confusing me lol
        So you have used simple ZYX with satellite, right? Or you've used satellite before with other FBL unit?
        Check this video, I've used it set up mine, but not sure if that man used satellite ...
        Roman
          Yeah, when I bought the 450 that's what was on. Had a little trouble binding to my dx6i, but did it and only use a satellite in place. Flys unbelievable, one handed even. This is what's causing me trouble, here to start lol. I don't use the software as I have Mac and it doesn't work, only windows based. It's the first FBL unit I've used and tried to set up. Literally had to strip her down to nothing.
            Your satellite is the receiver. That's why it's called a satellite receiver. It just has no pins to plug servos into.
            Invertix 400
            Vortex 285
            TBS Discovery Endurance
            X4 II
            Schluter Champion Longranger
            G4 E720
            G4 E720 Big AIR edition
            Goblin Urukay super slow
            Goblin 700 KSE Slow
            Goblin 700 KSE Fast
            Srimok Faifa
            Spectra G
            Synergy 766
            http://mangled-rc.com/
              That's the video I watched, he really confused me lol. I know it's known as a satellite receiver, but thought that little bit was an antenna extension? I'll watch the vid again (slowly) and see if I can sus it lol
                Could you take a pics of ur stuff? I mean satellite, cable between it and ZYX, and where're u going to connect it into ZYX.
                Roman
                  I can tell you where the wires went, as I wrote it down before I took it all apart. Cheers for tour help king, will have a look when I get home tonight
                    Looking forward for more info Cheers
                    Roman
                      I stand corrected, sorry I've got an "S" on my 450 and it's a normal ZYX on my 600. This is how it was set up.
                      AIL-ESC
                      RUD-SATELITE
                      CH3- elevator
                      CH2-aileron
                      CH 1- pitch
                      CH4 - tail servo.
                      Any help would be much appreciated
                        Well, so I was right. Connection looks ok, so have you set it up by ZYX PC software?
                        Roman
                          no mate, i havn't got the software as use mac and its windows based. Never had any trouble with the unit so never used the software. I've bound the satelite to it, but when i turn it on, just dont seem to get any response from it. all i get is the blue light come on after initializing. got the solid orange light on satelite, so that must be connected i guess?? if need be i can use another laptop with windows on.
                            Yes, seems you connected all right. But I've got red light on mine, blue one means your tail will operate in "normal" not "hold" mode. But I don't know your flying style, so I prefer "hold" mode I've read some manuals how to set up by TX but all of them were about normal receiver, not satellite BTW I recommend to try PC software (last one is 4.0) if you can.
                            UPDATE: Just found a video how to set up ZYX-S and satellite
                            Roman
                              i normally fly HH mode, just put into rate mode to set up. I'm on line now trying to sort software now. it's 4.2 now lol, but not using windows for 3 years is worse than setting up this dam tarot lol
