Motor Question
  • Motor Question
    I have a second hand Pyro 700 52, it has a little bit (2mm) of up and down play. I have a new scorpion motor in my trex 500 and it does the same.
    Wondered if it was ok to use or send it for a service.
    Controlled
    Warp 360 / Compass 6HVu
    /Trex 600n DFC
    HD Cell 500
    Youtube Channel - http://www.youtube.com/user/GavalarWright/videos
    Jimmyhorns is your man if you want them serviced
      It don't need servicing, At the top (or bottom depends what way you look at it) but where the shaft comes out there is a little locking collar. Line up the little hole in the case so you can get a small hex driver in there and loosen it, then push it all down and together then retighten with the tiniest amount of loctite. Them little screws strip easy!!
        Thanks I thought that might be it,
        but opps its stripped!!!
        Controlled
        /Trex 600n DFC
        HD Cell 500
          The pyro 700 is easy to service but getting shafts is a right pita, kontronik won't sell shafts for the motor. I sourced my own shaft and replaced bearings and shaft myself. Try re seating the sleeve as Ben said above. If it doesn't work I've got some blank shafts left if you need one.
          Invertix 400
          Vortex 285
          TBS Discovery Endurance
          X4 II
          Schluter Champion Longranger
          G4 E720
          G4 E720 Big AIR edition
          Goblin Urukay super slow
          Goblin 700 KSE Slow
          Goblin 700 KSE Fast
          Srimok Faifa
          Spectra G
          Synergy 766
          http://mangled-rc.com/
            Unfortunately the grub screw is shot. Might try and slowly drill it out and re tap the hole.
            I will tape the motor so no swarf gets inside. I might take you up on that offer joe, thanks
            Controlled
            /Trex 600n DFC
            HD Cell 500
              Hi joe are the shafts long or short? Looking for the longer ones.
              Controlled
              /Trex 600n DFC
              HD Cell 500
                The shafts are very long, and blank all the way down so no flats at all.
                Invertix 400
                Vortex 285
                X4 II
                G4 E720
                Goblin 700 KSE Slow
                Goblin 700 KSE Fast
                Srimok Faifa
                Spectra G
                Synergy 766
                  Which bearings did you use joe?
                  Controlled
                  /Trex 600n DFC
                  HD Cell 500
                    Just stock bearings from bearing supplys.
                    Sent from my SM-T315 using Tapatalk
                    Invertix 400
                    Vortex 285
                    X4 II
                    G4 E720
                    Goblin 700 KSE Slow
                    Goblin 700 KSE Fast
                    Srimok Faifa
                    Spectra G
                    Synergy 766
