MCPX battery parallel charging
  • MCPX battery parallel charging
    Can anyone explain to me how to parallel charge up to 6 MCPX batteries using the PL6. If I buy the lead in the link below will that work ok?
    https://www.modelhelicopters.co.uk/p...ct-description
    Align Trex 700XN VBar Neo with Pro Rescue
    Align Trex 550 DFC VBar Neo with Pro Rescue and Current Sensor
    Goblin 500 VBar Neo Pro and Current Sensor
    Trex 450 Dominator 3S
    VBar Control
    That's the lead.
    I guess the PL6 has a normal charge mode not balance mode.
    Use normal or fast charge to charge them as a 1S.
    Heli's: Trex 700 - os gt15hz : Goblin 380 & MSH Brain - Trex 450 Ikon : Blade 550x & 180cfx
    FPV: Sky Cruise 2400 - Cyclops Tornado - 700tvl cam
    SkyWalker - Cyclops Tornado - 700tvl cam
    DJI F550 - Naza v2 - iOsd - BT module - 700tvl cam
    Mini Talon - MFD - 700tvl cam
      Don't forget to add the MAH together and dial it in to your charger.
      This is the one I use on my multi 4
      http://robotbirds.com/catalog/produc...oducts_id=5369
      The Fleet
      Trex 450 Pro on Brain 2
      Mini Titan super Cobra ah1
      Alien 550 Quad.3DR Pixhawk
      Futaba 7C 8FGS 14SG
      Specktrum DX6i
        This is what I used for ballanced charge
        Quantum Parallel 6xJST-PH Charge/Bal. Cable UMX/130X/MCPXBL Q-CL-0031 | eBay
        Goblin , 380 Carbon
        Oxy 4 - 360
        Oxy 4 - 325
        Oxy 3 - 250 , 3s
        Oxy 3 - 250 , 4s
        Oxy 3 - 280 , 3s
        Oxy 2 - 190
        Oxy 2 - 210
        Spektrum DX9
        Revolectrix PL6 & PL8
          With the PL6 you will need to select 1/2s unbalanced for it to charge
            Thanks everyone. I've bought the lead that kennyd suggested. Hopefully I can get it to work ok with the PL6.
            VBar Control
              Hi keith , it'll work fine , I used mine with a pl6 , plug it in , select how many in parallel & how many mah, IE 250mah , it will tell you it's 2s , for discharge I think I set it to 500mah , so should be no probs , Kd
              Goblin , 380 Carbon
              Oxy 4 - 360
              Oxy 4 - 325
              Oxy 3 - 250 , 3s
              Oxy 3 - 250 , 4s
              Oxy 3 - 280 , 3s
              Oxy 2 - 190
              Oxy 2 - 210
              Spektrum DX9
                Cool mate cheers.
                VBar Control
